Tips for new torque converter install
Getting ready to install new billet torque converter in the old 47re.  Just wanting some tips on what else should be replaced while I have it out. Rear main, front pump seal kit? If anyone knows of a good brand pump seal kit let me know. Any other suggestions would be appreciated. Also, what's the best filter?
Edited by rlane547
  • Replies 16
  • Views 8.4k
How many miles? If you are just going to replace the converter just a new seal, but I would suggest you look into going through the whole transmission since you have it out. Has the old converter been slipping? Then you for sure want to make sure there is no friction material anywhere in the system. Give us a little history on the transmission and what kind of power you have.
Transmission and torque converter working fine. Transmission had been rebuilt shortly before I bought the truck. I installed the shift kit a few months back and its great. Just moving up to single disc billet converter for a little insurance since buying a new travel trailer. I've adjusted the bands and kept fluid changed regularly so far. I don't feel like the tranny needs any work right now. When I did the shift kit I installed a new governor pressure sensor and solenoid and temp sensor. Tranny runs normal temps with or without a load. Just wanted a little better converter that was low stall. I have already ordered a pump seal kit.
Well, looks like you have your bases covered! Just change the seal and run it. You are going to like the converter!
Yeah I can't wait. Like a kid at Christmas.
Mopar filter. What converter did you go with? Stall?
Went with Revmax converter because they are local. Basic Stage 3 with 300rpm less than stock stall.  Nothing major. Will order Mopar filter tomorrow.
Ensure you lube the shaft up to get the seal to work on the front of the tranny.
When I did mine I forgot this step and leaked about a liter of fluid out of the input shaft seal.
You want to make sure you have about 3/16 clearance - between the flex plate when the converter is pushed back into the pump all the way. If it is more than this, then use a washer between the converter pad and the flex plate. If using a standard off the shelf washer I would suggest getting a hand full and miking them so they are close the the same thickness. If you have too tight of a clearance between the flex plate and pump you could kill either the pump, or the thrust bearing on the crank. If the clearance is too loose you run the risk of not having enough engagement with the front pump.
I would also advise that you recheck the tightness of the converter bolts after you run it for a few hundred miles.
Mopar filter ready to be picked up. Thanks.
Thanks for all the tips. Looks like I'll be doing it Saturday and I'm going to print this thread and take it with me. Keep them coming.
Thanks again everyone. Installed the converter today and everything went pretty smooth.  It's a whole different animal to drive now!
It is amazing what a difference just a better converter can do!
MnTom, I cant believe it. The shift kit was a very slight difference but adding the t/c changed it completely. We have a 400 mile trip pulling the travel this week. Can't wait to see how it does.
Yea, it still amazes me how much HP is lost through a stock converter..........
As a drag racer one of the most important components of the combo is the converter. 300 RPM difference in the stall can make all the difference in the world. Of course my converter stalls at 6200 RPM..  The car will perform totally different if it stalled at 5900, or 6500...
