Another lift pump question
- Replies 15
- Views 3.5k
asens 6 posts
Mopar1973Man 3 posts
flman 2 posts
dobienut 2 posts
I have the stock lift pump mounted to the block. The lift pump will only run for about 1/2 sec. when the key is turn on, when I bump the starter the lp won't run, I tested the voltage at the plug to the lift pump, reads 8 volts.Anybody have any ideas? thanks for the help....
