47RE to NV4500 swap with minor issues
I just swapped out my good non-slipping 99 4x4 47re trans and installed a brand new South Bend clutch/flywheel kit, rebuilt NV4500 trans, and changed the input shaft on my 241DLD t-case. My friend entered my VIN into the PCM so there would not be any VIN mismatch codes thrown.
I swapped out my auto PCM with a 99 Dodge Cummins 5 speed PCM, connected the two outer wires from the auto trans NSS to the nv4500 reverse lights switch, ran the black/white tracer center wire up to the CSS, and then grounded the 2nd wire on the CSS to the left side under the dash where there is a common ground point. I'm still using the factory auto instrument cluster and the auto trans PCM wiring harness.
I pulled out my instrument cluster and removed the PRNDL shift indicator and installed the manual trans blank that goes in that spot.
The only issues I have are the seat belt light goes out after starting the motor, but then it comes back on and stays on while the pickup is running. My cruise control works fine like it should, decel, accel, and set, but the cruise light on the dash does not come on now except it does come on when initially turning the key on.
I haven't swapped the steering column out, still using the auto column with the shifter removed.
The cruise light worked before the swap, and cruise control itself works after the 5 speed swap, but the light does not light up now on the dash.
  • Replies 7
  • Views 10.9k
Could it be computer related?  I wonder if a whole reflash with your current trucks options may assist in the problems.  :shrug:
Power wise, it's like driving a different pickup.
I do have a 99 ECM from a manual Cummins 3500 if I want to go through the hassle of programming my VIN into it and testing it out. Everything worked like normal before my auto to 5 speed swap, and the only wiring I did was the auto neutral safety switch 3 wires - two outside wires to 5 speed reverse light switch, and center black/white tracer wire up to one side of the CSS, and the other wire from the CSS to ground. Has anyone just used the auto PCM and not had any issues after the swap?
Did swapping in the manual PCM clear the transmission codes and turn off your CEL, dealing with a transmission swap done by Previous owner and cant smog due to the CEL being on.
Edited by jphillips23
Don't worry about your vin number not being in the pcm, it means nothing to the truck. I did the swap and had several different pcm/Ecm combos and the truck didn't care. Pull the bulb for the seat belt and I can't help with the cruise. Everything worked like it came from factory with mine but I never had a seat belt light to began with.
Edited by 98whitelightnin
wondering  about the  old  column itself.     Is  there  a  position  sensor  in those  for  PRNDL  too?   might be  sending  some  goofy   info back to pcm.. which it can't handle
seeing  most of your  problems are in the cluster,   I'd  take back out and    check the  (not sure what ya call it)  'connection strip'??
before  doing this,  just whack the  dash  with your  palm a couple times..
Good thinking Robert, I left my column in P before I removed my shifter but maybe put it in D.
