Regulator Conversion
- Replies 15
- Views 3.8k
cbrew 5 posts
Cowboy 4 posts
Mopar1973Man 3 posts
MnTom 1 post
Hey,
I have a question and want to make sure i am not over thinking this,
I did the conversion a few weeks ago when my regulator in the ECM decided to go crazy and cook my alternator
i did the conversion that in the tech article but did come changes because it tried to overcharge (bad reference voltage sampling point)
with that fixed, I am now getting 14.4 with a high of 14.5 and a low of 14.3
so here is my question and concern,
from what i understand, the ecm would cut the alternator when the grids would cycle.
this conversion does not allow this provision. now i do have a circuit designed that will cut the alternator when the grids are energized.
currently the voltage will drop to ~12.8 volts at idle when the grids cycle
but is this really an issue? I am worried about stressing the diodes and alt fuse needinglessly.
what is everyone else doing?
I did install a manual alternator kill switch just in case I see an overcharging event again.
thanks again
truck is a 99 2500
