- Replies 6
- Views 3.6k
Dieselfuture 3 posts
JAG1 1 post
Yankneck696 1 post
Cowboy 1 post
Just a quick question I hope. I was wiring up a 5 pin relay to have on toggle switch from IAT sensor to 2.2ohm resistor. On accident I touched 12v positive from battery to IAT wire, so basically I sent 12 v to ECM from one of sensor wires. ( i cut blue one in half and piggybacked to black) I haven't started truck yet and it's getting really cold out too I might wait till end of week to start. But with key on and switch off I get 143f on IAT gauge and if I flip switch on I get ambient temp of intake. I figured ill wire it up this way so the relay is not energized when I'm fooling IAT, most of time it will be fooled anyway so I'll use relay to switch to IAT only for warm up and then shut off switch and be on resistor with relay dead. I guess I have 2 questions could I fry ECM by sending juice back to it through IAT wire and any side effects with the way I wired up relay. Thank you all for your help.
