Dodge missing at lite throttle and initial acceleration.
- Replies 15
- Views 2.6k
WesHawkins 6 posts
Mopar1973Man 4 posts
MnTom 2 posts
Buzzinhalfdozen 1 post
On an earlier post I was considering swapping my pump out to a friend and then ordering a new/rebuilt for me. Now that I have his truck here at my shop I am glad I didn't jump and do that. Upon driving his truck its misses and surges at initial throttle and at light driving conditions. When you put your foot in it, it takes off and runs great and doesn't miss or surge. It even does it going down hill holding it in third gear with very light throttle. The best example I an give you is it feels like a gas engine with a bad spark plug or spark plug wire. Differenece is Once you get past half throttle it runs great. As long as it has a strong pull it runs fine. I'm going to check lift pump pressure and for air but I really don't think that is the problem. I would think if the problem was with either the lift pump or IP it wouldn't run so well under heavy pull and throttle. I'm leaning toward a APPS or Manifold pressure or Map sensor. It is a 5 speed manual. Haven't checked for codes yet, the light is not on but did come on for him a couple of time but goes off after within a minute or two or after cycling the key off and on. Ideas??
Edited by WesHawkins
