- Replies 11
- Views 2.3k
440Rat 4 posts
Mopar1973Man 3 posts
Me78569 2 posts
joecool911 1 post
While I'm waiting for FASS to return a call I figured I'd ask here as well. I changed my fuel filter last Thursday and ever since, my FASS 150 is all over the place for pressure. I noticed this morning that every time the grid heater cycled the fuel pressure would build to 15psi, then drop back down to 12-12.5psi. Running down the road it continues to bounce between 12.5 to 15 some times it will spike at 18psi, then drop back to 12.5. Driving style doesn't seem to effect it either, Sunday driver to hot rod it doesn't drop below 12psi. Before I changed the filter it ran a constant 12.5psi and would jump to 15psi at start up then drop to 12.5. I bought a new water separator after work today to swap out the one that's on there, and other than pulling lines to look for debris I'm outta ideas. FASS states these pumps are preset to run 16 to 18psi.....
