Intake Manifold Gaskets
- Replies 14
- Views 7.1k
notlimah 6 posts
Mopar1973Man 4 posts
Yankneck696 3 posts
CUMMINSDIESELPWR 1 post
It was time to fix some of my minor boost leaks and whistling sounds coming from the old manifold gaskets. So since Lindy wasn't busy and the gasket where their at work why not? So I got a nice dry spot to work inside and all the tools I could ever want.
So I will tell you that you want to remove all the injector lines. The fuel filter has to come off (if you still have the stock fuel filter). APPS sensor has to be removed and the intake horn and grid heater of course. Take a nice sharp puddy knife and start scrapping off the old gasket. It will be baked on so take your time.
Then once cleaned up I put a very fine layer of black silicone on both sides of the gasket. Re-install the plenum. At that point its just a matter of re-assembly just the way you pull it apart. What I did was place all my bolt back in there holes but as I started installing injection lines just lift out the ones that hold something. Then replace them.
