door lock solenoids
Any one fiddle with door lock solenoids
My pass side is sticking . Makes a noise wont go up and down with the drives door switch. Once in awhile it works
Maybe just needs a shot of penetrating oil
Havent felt like pulling the door panel and busting the plastic retainers yet   :cool:
  • Replies 7
  • Views 2.6k
Don't pull them out, pry and cut each one otherwise the door will break on the inside. The plastic is way too brittle
They all slide in from different directions. I go around popping the panel off gently as possible and then put them back in the door panel for reinstall. I need to do the same to mine, drivers door lock works 1 out of 100.
:thumb1:
Does the plastic door panel break/ crack where the panel retainers hook to plastic door panel?
Do the retainers slide into a grove on the plastic door panels ?
Both, exactly
