  1. Some of the early articles talked about 19 to 20 BTDC at 2k RPM. Which I figured out is wrong. Timing is based off your pop pressure and how far is strays from the 310 bar which is 4,500 PSI. I'm at 320 bar with 4,641 PSI which is about 2 degrees retarded hence why I can reach 26degrees at 2k RPM with timing. Now someone with a low pop pressure say 290 bar could be about 4 to 5 degrees advanced and would have to retard timing. Just seeing his running timing he's retarded to deep yet. Should be some where around 22 to 23 degrees at 1,900 RPMs. Take some time watch stock timing on level 0. You can add about 2 to 3 degrees more over stock. Only one catch cruise timing has to have 5 PSI of boost or LESS. Don't wanna blow head gaskets.
  2. Actually still doing pretty good today. I'm being lazy I need to hit the shower and get dressed.
  3. So what is you max timing for 1.5k, 2.0k, 2.5k, 3.0k RPMs? Light throttle load limit? Then light throttle timing advance?
  4. Well this is chemo #3 another big one. I'm up this morning made coffee 2 cups and then later made steak and eggs and plowed that. Not I'm helping a neighbor/friend to get there new computer setup with Ubuntu Linux. I'm feeling fine and have a good grip on my meds and use of cannabis to have a normalish life again. Down side... im losing my hair fairly rapidly. Now since I've done my pre-planning I've got my wigs and makeup down to a science. It's to a point that I must wear a wig just to keep the loose hair out of eyes and mouth ans it just falls out. This morning shower I managed to plug the drain with my hair ball. So wig life will continue now. Hair problem is bad enough I wore my glasses just because my contacts are sensitive to the hair and how it fouls my vision. Yup this is how I rolled into chemo. All my staff love the wild look and something different each time. This picture yes my glasses are on but I wore them for the day since the frames are blue too.
  5. Info needed... Boost at 55 and 65 MPH Engine load for 55 and 65 MPH Timing for 55 and 65 MPH Let's see if ican get you to ride in cruise timing and alot of people don't return to get that programmed up right. Double checked... addon. You matched with me. So let's look at the tuning more in depth.
  6. Final ratio is huge. I'm running 3.69:1 final ratio. Below 3.55 is hard to to tune out because you will be required to manually keep your RPMs near 2k for optimally. Too low of cruising RPM could be considered lugging because you too low in RPMs.
  7. Thank you sir. Thank you for bringing my product back to the market place. I know many people have been asking if it would return and when.
  8. Just info purpose... If your running a Quadzilla tuner the IAT isn't really used. You'll gain more from proper timing than chasing IAT mod that isn't really used in Quadzilla tuning. Things to be aware of... Pop pressure your injectors are set too. >310 bar timing is retarded by the injectors means it's late to fire being it needs more pressure. You can add timing. <310 bar timing is advanced by the injectors means take away some of timing being the injectors are adding it mechanically Proper timing your engine oil temperature should be -30°F cooler compared to coolant. So if your engine oil temperature are high then your timing isn't set right. Just keep in mind I'm running 26° BTDC at 2,000 RPM on cruise timing pushing me into the mid 20s for MPG. The biggest thing is your boost pressure MUST BE 5 PSI OR LESS!!! Do not attempt to run high timing with more boost or head gasket failure could occur. This means you have to keep low engine load setting on your light engine load timing. As your setting timing if engine load goes up then your going the wrong way. If engine load is going down then MPGs are getting better. Trans temp is engine oil temp. Coolant will flip to -40°F when coolant is over 204°F and I'm reaching 210°F with my 200°F thermostat. 55 MPH for me in 5th gear is near 1,600 RPM with 22° BTDC. Again proper timing nets way more.
  9. Sorry being ive filed a NDA with my vendor I'm not allowed to provide that information any longer it would be a breech of contract. I'll have a link soon for the new product.
  10. I wish I could help. I'm down in Ontario OR. If I wasn't doing my cancer I'd be in the shop getting those measurements. Sorry.
  11. Pop pressure alters timing like my setup with 7 x0.010 popped at 320 bar is about 2 degrees retarded. Then monitoring my engine oil as long as engine oil is about 30 degrees cooler than coolant then time is close to right. Lower the engine load better your timing. This is why I can run 24 to 26 degrees at 2k rpms.
  12. I'm working on bringing my high idle kit back to market. I'll keep you all posted.
  13. How about being there for me? They say the phrase and leave. Gone. Not even there for phone calls. People quietly praying in there comfortable home isn't there for me. That not picking up the phone and even checking to see if im alive. Most of these people don't know if im even breathing being they have never called or stop by to see. I've got people that are actually are coming into my life to help me get things done im not able to do. I have wire work in my attic. Yes I've got a guy that is going to do it soon. Wire in my other camera, the existing camera for my security system. Then fix a fail on my part with my wifi antennas. Prayer isn't getting this done but people willing to be an advocate for me are getting things done. I've been that advocate for years for everyone else in the diesel community. Here I struggle to get simple things done like getting my trash hauled to the dump. Again prayer isn't getting the jobs I need done like cutting up firewood, splitting it and getting it stacked in the shed. This is why Dan Catherman a guy I know very well he is religious too but instead of praying he's now stepping up and being that man of action to help me get things done. Einar is another that will replace Jake soon and be renting my basement bedroom and be here to help me out and get things done like the firewood and keeping the stove burning. There is 2 people that being that Man of Action and not just praying at home. Yeah I've got others that still pray for me but again they call on a very regular basis of time. I've got another that we sit down and reading Bible verses together. But again this is more than "I'll pray for you" and vanish to never be seen again. HUGE difference.
  14. It's Sunday. Tomorrow I've got my doctor appointment in Riggins ID then afterwards head to Ontario OR to get ready for chemo. Oh fun... Yeah I know I've got to do my treatments but I'm hoping I can get ahead of it and control my nausea like my last run. I never even felt sick on my second treatment. Maybe from what I learned I can do it again. We will see. Here is my good news. I've now seen it twice now where my weak right kidney decided to pour the coals to it and exceed the output of my left. Yup it seems my right kidney is trying to play catch up. Then the Sour Tsunami I'm smoking tends to make it so a pee normally by opening my tubing between my kidney and bladder. Some things are starting to change in me more and more. I'm starting to win it seems. Also it's been very strange to have people that are more so in my world and how they support me. Compared to the ones that said "I'll Pray for you" those people vanished. I've got people of all walks of life that are there for me and trying to help me even by being there in a phone call. I've got people trying to heal my body with idea, then ive got people that are healing my heart, some that healing my soul. This is much more than having a parting comment "I'll pray for you" then vanish into the darkness to never be seen again. To all those saying in touch with me I say Thank You all for being there for me in my dark times. Thank you for being advocate for me.
  15. Well, I'm still here and doing good. This was a try at mostly blue makeup my eyes are a two-tone blue and only black was used on the waterline of my lower eyelid. Now there was a stopover a Walmart. I was picking up supplies for myself personal and also medical stuff I use. Believe it or not, a guy from NAPA caught me in Walmart. Yup, he called me out which is fine but gave an update on the surgery I was doing. He was glad to see I was doing good and no I'm not shy about going out and seeing people dressed up in my Emo Goth mode. People around do care and want to know how I'm doing. One of my stops is the Council, ID NAPA store, and say "Hi" to the guys that supply me parts for all my jobs in the past. I've had some bleeding issues with my left bag. I made the appointment to have both bags and plumbing all changed again into my back. This time I made the trip in makeup and my light blue hair. Boy, I was so happy I did. The lucky stroke was the nurse I talked to on the phone to set up the appointment was the very same one I got when I showed up. He loved the look. While I was getting ready for surgery my doctor showed up and I explained how the ports in my back were very sore. My doctor said he'll upgrade my stitches on both ports to silk the replace fishing line-looking stuff. That in itself feels much better in my back. The surgery was a total of 15 minutes again I did it with no anesthesia again. I don't feel anything in my back as he removes but inserting the new tube it feels like my guts are moving in front of my belly. I was in and fresh bags and tubing. It's like from the center line of my hips to the back I'm more or less numb and don't feel anything. Now from that center line forward, I can feel pain when feel disconnected being the rear nerves are more or less shot. I was treated like a king during my whole time in the hospital. After my surgery, I was released and was hungry. I stopped over to Golden Coral for a buffet-style restaurant to eat. While I was there the hostess that was working my section was making sure my drink never got to 1/2 full glass and making sure I was not running out of plates. She hung around and again people were curious. Very cool hostess and she made my time there simple and well taken care of. Personal Note: Yes my makeup work and appearance do make a huge difference in the way people treat me. Even with the shirt I was wearing which states, "Fun Fact: I Don't Care." Show off how my makeup artistry affects people. This is the very next day I get a text message saying my meds are ready in McCall ID. Mark and I ran up to McCall to do some shopping and get supplies. Mark headed into the store before me as I was on a phone call and needed to finish first. As I came into the store this gal was kind of dancing to rhythm in her head as she was heading towards me. She spotted me and danced up to me and said I looked like I needed a hug. Then the comments about my appearance. She asked if my hair was a wig or not and she wanted to try it on and get a picture. She was giggling like a schoolgirl and enjoying the moment. I got my wig back and asked for my photo now. I kind of cheated on makeup that day being I was still a bit sore from the surgery and the tubes still moving inside. I did basic black and no color. I darken my eye sockets into my nose more so. Still, a shock to have a random woman just walk up hug me, and want to just be part of my fun moments. Even with the shirt I was wearing that day, you can't see, "Don't Like Me? F__k Off Problem Solved"
  16. I've not had to replace the bolts in any of the gasket jobs I've done. Just do not use any sealants on the gasket it's not required.
  17. PCM controls the Overdrive light. ECM controls Wait To Start light. This is the only light that the ECM is in direct control of that is wired directly to the light. P0381 code would be present if there is no circuit or light issue for the Wait To Start. Only way to test either ECM and PCM is to send the modules to @Auto Computer Specialist and let them bench test the modules for you. Look at pin 37 is Wait To Start. Look at C2 pin 14 which is the Overdrive switch Cluster wiring... You can see the O/D switch. Orange/black pin 8 is your wait to stat from the ECM.
  18. I wanted to share my next idea for my makeup work. I've already used this one for my chemo treatment and my chemo staff loved the look. I'm trying to keep people on their toes being so far I'm enjoying blowing people's minds. Like last night I went to BBQ with a few friends in Riggins ID and was dressed up in my Blcak and Blue hair but I'm playing with other makeup concepts and so far people don't even know it's me any longer. Few people now had to ask Jake who I was and then when my cover was blown it was funny because they couldn't believe it was me the Mopar1973Man decked out in Emo Goth looks. Newest concept... Being I'm still dealing with my cancer. It's nice to be dressed up and enjoy my time being out and about sharing my makeup and Emo Goth looks and just forget about the fact I'm constantly hurting with these ports in my back and dealing with cancer. The fun of putting a smile on other's faces and then also putting a smile on me even for a short time. You all have to remember I'm limited on what I can do here to be productive right now and can't work on Cummins diesels. This has been a huge way for me to enjoy the time that I'm hanging out till my big surgery where I'll lose my bladder and prostate. Did you know my sexual organ (one eye) will no longer function? Yup just consider the fact I'll never enjoy sex again and I'll never piss like a man again. So again people might think I'm off the wall... I don't care. Why? What if this was my last chance to enjoy life and only could live to June? What would you be willing to do to enjoy life? Yeah I know I'm not going to die anytime soon but it makes you think. Consider my position that sexual I'll no longer function any longer. Just consider that every day I get up alone and really can't do anything. So you start looking to interact with others just to have some enjoyment. Hence why I'm enjoying some makeup artistry and just getting my feet wet and have to learn a lot very quickly.
  19. 2.49 and 2.51 respectively after all communication is done.
  20. I loved the fact when I was leaving and I stopped out front to make sure everything was is check before I leave. I had all the receptionists laughing as I left the building. My case worker loves the energy I bring to the build while I'm there. Amount of people wanting to just ask What's your story. Oh I did find the photos.
  21. Good morning gang... Chemo run number two over. Being I had a chat with my pharmacist and knew what is was dealing with I've be taking care of my meds on a tight schedule. This morning I got up and feeling super good. No nausea and my energy is good. I do have some medical things to sort out with my doctor.i hoping for my phone call this morning so I can get things checked out. I feel good enough to actually sit down and do code work on the server. First let me get my doctor visit handled and if im still on track I'm going to get busy working tomorrow. I've got a story on my chemo visit. My IV nurse requested for my light blue wig and metallic blue eye shadow makeup. Sadly I got there and Rusti wasn't in being her kiddo was sick. Strange enough the hospital Chaplin walked in and seen me and sat down and asked What's my story? Well it went all over from past, present and future talks. He was giving me props on my look and liked the light blue hair. He hung out till my chemo was done. Shocked him to tell him I'm a internationally known Cummins mechanic and showing off the website. Like I told him even spiritually I'm in order and explained how thankful I am for all the medical staff has stepped up for my needs and getting excellent care.
  22. Biggest thing is to see if you got the bias voltage of 2.49 and 2.51 on the bus. Then hunt down why the bus might have a voltage offset be it 0V, 5V or 12V either a short to power or short to ground. Could be a open circuit. I'd suggest getting in contact with our Vendor @Auto Computer Specialist and ask some question to give more clues.
  23. Yeah I get it. I'm on the other side dealing with my limitations too (money & health wise). I know this has been a super long running project. Hopefully I'll be able to build my project ride after my cancer treatment. Still planning on building a C Body Mopar on a 2nd gen frame that will have also a 6BT Cummins. Just gotta take care of me first then I'll most likely start next year.
