bry1216
  1. FYI - I looked up my history and I have 8.5 years on my GATE K080810 and it started to chirp. I remembered Michael Nelson told me in 2015 "next time just rotate the belt to get rid of chirping" - so I did December 2022 and it worked! I am just deciding what to buy for a backup! My total mileage is ~116,000 and not sure if a new tensioner is needed, but then again it is becoming an ancient engine - in the thought of part replacement!
  2. Gates K080810HD Micro-V Gates K080810 Micro-V Other ideas that last a long time?
  3. Please explain or show image of this: DTC Good Trip Counter Also any images of the map sensor output wire.
  4. I am not sure what a Drive Belt Adjust is?!?!?! I switched to Gates, because all my other belts would get tons of cracks. Gates does not crack, but it does create a metallic squeak as the belt groove shrinks. If you hear it, squirt water at the groove in belt. Belt grooves thin, leaving space and metal roller/pulley acts like the old phonograph records (vinyl groove and needle produce music). Water is a non-compressible thus it fills the groove and immediately no noise for 10-20 seconds. I cannot predict how many cracks in a belt before failure, but I can predict the metallic noise and a 2 yr warranty :-)
  5. Welcome. You need the Fleetguard Enviroguard Kit - absolutely no more mess!
  6. I have the instructions. Works perfect on my truck and Michael has personally look it over. Working fine sine March 2013. I believe specific to 1999 year. Image No Relay Jump 3-5 is part of Fog Lights on during High Beam. I am sure you can find the schematic for 1999 and your truck year with a little help from support group here. Headlight Harness Instructions 2014.pdf
  7. Nothing like a little age, a few scars and a wrinkle or two. Happy B-day!
  8. Mine was replaced Aug 2012 and it required those darn screws in the dash outlets. I believe removing the window would have been the easiest option. I purchased an oem replacement dash and I was told plastic technology had changed since the original dash was made and this should last longer. Only time will tell.
  9. I would suggest you watch the steering box as it will flex on the frame during initial turning of steering wheel. I installed the DSS Steering Stabilizer (http://www.solidsteel.biz/) and the DSS Solid Track Arm Kit (or adjustable track arm) at the same time. I had both moving steering box and another failed joint on the oem track arm. This really firmed up the turning of the steering wheel and no more rut grabbing the front wheels and jerking the truck sideways, but I still have a little "typical" back & forth slop - it is either adjustment in the steering box or the rock solid bearing replacement. I am going with steering box adjustment first.
  10. Small correction Michael - There were some codes in the beginning, but it was P0236 and P0382 codes and I found the plug in control wire off. From the time I cleared it to pulling the MAP connector P0237 - cleared it - and after no codes. I check all the grounds to the body in the engine area. If anyone get time I would like to know your ohm measurements and socket size (determine if it is original or later Cummins part).
  11. Replaced the original sensor with new Cummins 492147 (Geno's Garage) and problem fixed. Look at the ohm readings of new and old and the opening size. Socket size: Old sensor 1 1/4 New sensor 1 1/16
  12. Has anybody installed this without removing the steering column on an automatic? http://rocksolidramtrucksteering.com/ Looking for instructions and feedback.
  13. Codes do work. I pulled MAP connector and got a P0237. I pulled both MAP sensor and IAC. Both look really clean. Reinstalled and same problem. I did notice the BST at 0.0 until water temperature was 170'f, then BST jumped to 22.1. Temp rose to 202'f and then cooled to 190'f and stabilized at 195'f. Do anybody have a ScanGauge 2 that could describe the BST values they are getting? Thank you.
