Seat belt light
Well I think I’ll remove it and see if I can find a similar one from maybe a later model Ram and see if I can make it work. If I do I’ll post which one I used. Yes, it’s held on with 1 screw, easy. There’s a harness coming out of my latch on the driver buckle. 2 wire with a connector.
Seat belt light
I’ve been killing some gremlins in my truck lately and this is the last one. I’ve had the 3 horn honk when unlocking the door with my fob for the last 15 years that I solved by wrapping the ctm in foil tape…this blows my mind. $6 from Home Depot. Unbelievable. The last is my driver side seatbelt latch switch is i think the issue. The dash light stays on but if I wiggle the latch just right it stays off. I think the switch contacts inside is worn out. Has anyone found a seatbelt latch that’ll work (they’re discontinued) or is the switch serviceable?
Lost coolant - engine got hot
If you want to refill coolant properly use a vacuum tool such as Snap-On sells. If your cooling system is in a vacuum coolant will enter every crevice where the vacuum is, hence no air pockets. This is the only way we do it at Freightliner as air pockets can develop (such like in a egr cooler) that don’t necessarily burp out right away.
Group 31’s
You betcha!
Group 31’s
I read an article here about modifying our existing battery trays to accommodate 31’s. I pondered it but I decided to go another, more expensive route for some reason. LRB Speed makes “put together yourself” aluminum ones for $400. I run 925 CCA Detroit Diesel batteries (from my work) and I’m pretty happy. They’re made well and even a proper spot for the temp sensor on the driver side tray. I had to relocate my horns but other then that they fit and lined up great. With my Nations 180 amp alternator I feel it’s a good combo. My old 27’s were 750 CCA if I remember correctly. This will help with running my Webasto coolant heater I have as well running in cold mornings. Enjoy!
Mace started following P1693 and P0121, Surging, dead pedal AND runs just fine , Group 31’s , Yoke Grenaded and 1 other
Suspension fun!
I’m absolutely gonna get a air ride hitch and convert the trailer for gooseneck. When I do tow it I’m gonna convert the back to dually as it will put less stress on just two tires. That’s why I want 3 axle not 2. Distribute the weight better.
Suspension fun!
I think it’s 3k pin weight. I’ve seen one truck the same as mine (still a dually) do it from La to NC. It’s doable. I have a trailer brake controller, exhaust brake, 3rd gen brakes and a 6 spd. That’s just the trailer. I’ll never haul it loaded with water or anything. It’ll be overweight for sure but a Dana 80 can do it. That’s the only thing I think is somewhat weak on our trucks is the frame. If I could sit my cab on a F450 frame I’d be so happy.
Suspension fun!
I have the 6 spd so I’m not changing anything that way. I’m buying a new 3 axle toyhauler that’s about 44’ long and 16k lbs. I’m gonna buy some extended Synergy rear sway bar links and the Timbrens as well just to make it as bullet proof as possible. I actually ended up reusing the oem blocks so I could use Timbrens, the taper is too excessive and no matter how you install it the pinion angle is too far off. That’s a mistake on my end I though it would correct this. The oem blocks made everything perfect again. Most likely crack the frame but the springs should be fine :)
Yoke Grenaded
And this is why I went to a flange.
Suspension fun!
It’s time to “spring” into action! 8 leaf 4000 lb pack 2 leaf 1150 lb overloads New shackles (All from Rockauto) I used 4” blocks from ProForm Fabrication (they’re also tapered to get the pinion angle straight too). I didn’t want the *** end to sit up super duper high so to compensate for the thicker pack I used slightly shorter blocks (my oem blocks are 4.5” tall). Old leaf pack is 2” thick and the new ones are 3-9/16“. The bolt by the fuel tank is not really an issue. Just cut it off flush with the hanger and you can drive it all the way in without hitting the tank. You can fish it out with a magnet and then put the new bolt in from the outside. I used locally made 5/8” ubolts and my old Barnes4wd top plates to keep the flip. For the eyelets I used 5/8”x 5” fine thread bolts with stover nuts. Removed the old bump stops since they do nothing now. My truck is a 2001, so it’s time for new springs. I can’t use airbags because unless it’s the c&c kit my gooseneck hitch interferes with the mounting plates. Also the c&c kit sits on the oem block pedestals and I don’t have those anymore now. Next up: Rebuilt NV5600 & clutch from LRG. Enjoy!
Timbo is a repackaged Williams Control. WC 131973/133284 is what they actually are.
Radiator Lifespan
Then I may be interested. If you know a tune that’ll make it run better I’m all ears.
Radiator Lifespan
I’m sure there’s a lot of trucks with more miles than me. I’m pretty happy with 25 years. Even if it dies tomorrow I’m pleased it went this long. I’m also sure things like the VP are built better today then when they came out.
Radiator Lifespan
I had the oem lift pump (in conjunction with the GDP Fuel Boss) until my ecm failed earlier this year. Now I’m rocking just an Airdog 100. I’m too nervous to program my truck just in the case the tuner fails and takes something else out. Although I’m curious to see it “woken up”. New trucks leave me in the dust and I’ve accepted it haha.
Radiator Lifespan
Luck mostly. We didn’t actually have to change over to ULSD for a couple years when it was introduced. When it was finally forced I ran used 15w40 (just the stuff from my oil changes) with every fill up (switched to 2 stroke oil after reading your article on it). Also, I never had the Carter lift pump fail like so many did in the beginning. By the time I switch it to the GDP Fuel Boss it just wouldn’t die. Also I have never run a tune either. I have Bosch 40 hp injectors but power wise it’s stock. That’s the key thing. P7100 are oil lubed and VP’s are with fuel. So mostly just luck.
