Tim Waldo
Staff
Everything posted by Tim Waldo
  1. I may do that with the old one.... just afraid to do it when I "need" the truck up and running.
  2. and the only place that makes sense on a newly reman long block is the Turbo Shaft seals... that and I mean it JUST started drinking oil in the last 700 miles and I'm 17k on the reman engine. Turbo has 450k miles on original. Reman Turbo ordered, sadly won't be here till Monday so NEXT weekend before I can do anything.
  3. but a quart every 200 miles?? I'm pretty much betting on the turbo... guess I'll break it apart this weekend and see if I have residue on the exhaust side.
  4. none... https://photos.app.goo.gl/PHtop7t4BVnAiWD57
  5. No I haven't broken the turbo loose... if I'm going to that level I'm going to just replace it... no oily mess, no visible leak. No "obvious" smoke... Would it smoke if it was leaking out the exhaust side of the turbo? I mean I'm down to two possibilities... oil rings gummed up or turbo leaking on the exhaust side... unless I get other possibilities from the group...
  6. all I can say is I have done nothing but give 865Diesel grief over their shoddy work... so I wouldn't doubt I got someone else's dip stick.... SO... I did some research and once again 865Diesel screwed me over.... new long block CAME WITH new oil pan and new dipstick... The length is the same (45") but I"m sure the markings are off... 11 quarts shows at about 5" on the photo... The dipstick they sent back with the truck is #3935648 GENOS says the correct # for the 2000 5.9 is #3944594 correction... Genos says #3935648 IS the correct replacement and #3944594 is what it replaced.
  7. So 17k on a reman long block, initial 1000 miles were broke in with synthetic oil (against manufacture requirements) as soon as I learned I flushed and refilled with DINO oil. That being said, I'm now at 17k and loosing about a quart every 200 miles. I REALLY believe it is my turbo (original to the truck, currently 451k miles. Not blowing smoke but the tailpipe is sooty... no oil "leaks" under the truck. If the turbo was leaking oil, how would it be indicated? at $600 to get a reman from Thoroughbred Diesel and I just better replacing the turbo than paying a shop $300 just to find the oil leak? Is there a better/cheaper place to get a reman turbo? WHAT is the possibility that 1000 miles on synthetic could have caused issues with the OIL ring on any or all of the pistons during break in? Thanks guys.
  8. well I know what my oil is at the given oil placement on the stick... I'm good... was just curious why it changed... at 11 quarts, it shows a quart over.
  9. honestly I don't know... the installer was over an hour away so I couldn't keep as much of an eye on them as I would have liked.... I PRESUMED it was my original pan.... dipstick seems to be my oringinal... but again who knows.
  10. So my truck a 2000 5.9 ALWAYS took 11 quarts which would bring it up to the bottom of the top line on the dipstick... Two years ago I had to have a reman long block installed and now 11 quarts makes it look like I'm running a quart over on the dipstick.. Has anyone else noticed a difference, I've seem people arguing on-line about how much oil to fill when doing an oil change so it is possibly a real thing. Just thoughts that have been bugging me.
  11. So a Geno's cooler (single sided) would be a waste of $$? I'm about to change my transmission oil and now would be the time to put a cooler on. I don't tow much but on my last trip to Florida(not towing) my temps got as high as 205. Did you make your own heat shields? or buy them somewhere? Thanks, Tim
  12. So it is going to take more diagnostics on circuit B, there was no voltage through A at all.... I put in a push button to get by for now (I actually wanted a push button as an additional layer of security) I am pretty sure the ignition switch just bit the bullet. So by chance do you know where the bypass is for the clutch bypass is? Always a good to know. THANK YOU for the schematic. Tim
  13. So, 2000 RAM, 5 speed. I have bypassed the signal wire and jumped to 12v and engine starts, I have checked all fuses and relays (to best of my knowledge), I also jumpered the clutch safety switch which did nothing.... Wait to start light still works as expected, what would keep the 12v signal from making it to the starter? I know I can just put a push button in to bypass but I want to make sure this isn't a bigger picture issue. This literally popped up outa no where, stopped at a store, and when I got back in it wouldn't crank, I had to roll start it, luckily was on a slight slope. Thanks in advance. Tim
  14. Yes painful to the extreme, the shop did not help matters ANY... Vette your shops if you are going to trust your truck with them.
  15. That is AWESOME... will remember for future reference.
  16. SO... I broke down and called a local Dodge dealer... they looked it up for me. They had to look from the transfer case side to even get the grommet part number... but with it I was able to find THIS. https://torqueking.com/product/10589/qu10589-transfer-case-shift-linkage-grommet-or-bushing-for-dodge/?dfw_tracker=64486-3171&cmp_id=17998788702&adg_id=&kwd=&device=c&gclid=Cj0KCQjwmvSoBhDOARIsAK6aV7jyF49S_6OWbRI5zVCtBeIdLBKnFGmzPpYmHND-6rXCilird-QUf90aAhtrEALw_wcB
  17. I just want my gatorback belt back... best I can tell they have quit producing them.
  18. SO... finally got my truck back at the first of August and though I no longer trust the shop, this is what I THINK happened. VP44 died, was replaced... started throwing codes for the IAT almost immediately.... New VP44 was replaced as a failed rebuild, upgraded the VP44 and ordered injectors and tubes and a new IAT sensor installed 2nd VP44 with new injectors and tubes, still through IAT codes and melted a 2nd IAT sensor Sent to a shop. They found cylinder 5 in some state of disrepair (this is where I loose trust in the shop) I don't know if the cylinder had a hole in it or what. (shop ordered the wrong long block first and installed it wondering why truck kept throwing a crank position code) Shop corrected the long block issue and installed a 2nd new long block, with new injectors and then there was drama with break in oil (they put full synthetic in it for break in and post breakin) never got me the warranty paperwork and eventually I contacted the remanufacture shop, got specific directions on breakin oil and started that process over and ended my relationship with the shop. Currently breakin with DINO oil is complete, and I have my truck back again (after $14k repair bill).
  19. The shop that was doing the work on my truck got a DORMAN replacement and it didn't work at all. The kicker is I'll find something specifically listed as a replacement for a 2000 dodge but then when you look in the details it is for 2002 to 2005 or something like that.
  20. I just need the bushings for a 2000, 3500. I'm not trusting what I am seeing online. Where would you guys purchase?
  21. So final repair. 10mm OD aluminum pipe , two wraps of electrical tape, some rubber fuel line and some plumbers putty.
  22. So I ordered this tubing, it was not actually 10mm OD, it was 9 by my meter (cheap plastic from harbor freight).... SO cut it in half so I have 2 6" pieces and tried one for size... it was way loose... I marked it for depth about an inch and half pulled it and cut it down a bit more. I then got the electrical tape and played with how many times to wrap it to get a snug fit (about twice) placed it in the hole and extended with a bit of tubing that I had that would fit over and zip tied the tubing to the frame to secure the tube a bit more. Going to make a 100 ish mile round trip and see how it works. If anyone were going to order similar tubing from amazon I would try 11 mm OD. OR go with the 10 and know you'll need to add something to take up the gap. Total metal tube length was 4" when I was done. Photos later.
  23. THANK YOU... that is exactly what I needed. Yeah, prior to this I had a foot long piece of water hose clamped to mine. I am VERY frustrated with the shop because I am SURE it happened on their watch and they are totally denying anything happened. I'll let you know how this goes...
  24. The problem is, where you have a nipple sticking out past the firewall.. if you look at my photo, mine is recessed into the firewall... looks like it has been cut or broken off. If you could verify I would REALLY appreciate it... I miked the ID at 3mm, someone confirming would be AWEESOME. I actually ordered some telescoping tubing from amazon in hopes one of the sections would fit inside of the pipe and I'll cut it off and epoxy it.
