ROAD RAGE
Everything posted by ROAD RAGE
  1. Na, Havent done nothing.It's did this before after sitting for awile. Now when I start it, It'll be low on power steering fluid. The truck sits in a heated garage around 60deg. It been in the same spot for a month, (not started) all of a sudden looked under the truck and it has power steering all over the floor. Checked fluid leval and its over full....... EDIT;That's why I'm thinking it's draining down/back into the power steering pump housing..........
  2. Yes the power steering fluid, It's leaking out the cap, (on the pump) I was thinking:duh: beening the booster was higher than the pump the problem was it's draining back down and over filling the pump housing after setting awile. Ed.................
  3. Is there a check valve in the power steering pump to the booster line/or line it self ?????? The reason I ask is mine, (after setting awile) Starts losing fluid out the fill cap.This is the second time this has happen.Is this normal for this truck or is there a problem? I'm thinking I need to drive it more.:pray:Thanks Ed............................................
  4. Mike, sence I'm no longer running the power puck, Do you think if I install the RV/275's with the stock motor it'll get me close to the power/performance I had or will it need other help?The reason i'm asking, I'm not looking to hot rod in any way. Just kick it up a little, like the puck did with out the other problems. The puck only had appx 5000miles on it, wont trust one again. It did make pulling the trailer alot better.Thanks Ed.
  5. For the record: Unhooked the power-puck, the truck is back to stock, Took a test drive about 30 miles and the result was:Oil Pressure was higher by at least 20 psi. (60 idle warm) 85-90 Coldtruck ran better, wasn't A slug anymore, ran like it did when it was new. (an still is 67,000 mi):thumb1:Hooked up the code reader and: NO 5-VOLT SUPPLY CODES.I'm thinking the puck was deff. the problem. Still cant figure why the mileage window shows: PCM=1763 done & ECM=1693 done? I know there companion codes but why won't my reader pick them up. Reader says: no-codes found (passed) and how do you get rid of them. my code reader is a 200.00 buck ACTRON.Thanks Ed. Oh by the way, the transmisson shifted a ''LOT'' smother, didn't have the hard hit going into the higher gears. before with the trailer loaded and (in it hard) it seamed like it want to throw the u-joint's out:rolleyes:.going to miss the extra power it had from the puck, but i'm thinking of leaving it off.
  6. I haven't check the 5 volt at the ECM, after reading mikes post i'm woundering if my puck is out??? it plugs into the map. and the truck has been running weak, my next step will be to unhook the puck and see what happens. would this be possible??? thanks Ed
  7. Been trying to get this thing fixed, Went through the grounds and the 1488 and 522 codes keep coming back. Trying to trouble shoot from the book but seems it's just getting more confusing:mad: The book:1488= Auxiliary 5 volt sensor feed is sensed to be below an Acceptable limit. 5-volt Supply Voltage low. Sensor Supply voltage for E C M sensor is too low. book: 522= Oil pressure sending unit voltage input below the min acceptable voltage. Question? is there a sensor that supplies 5 volt's to the E C M?I thought the E C M did the 5 volt thing.:rolleyes:Thanks Ed.
  8. Well if that's the case, I stand corrected,,,,,,,,,,,,If your wanting a new one it's a no brainer,, Go to the dealer and order one.
  9. Mine does both, w/p-done, I'm sure its green, but sometimes I just get a companion code (on both) with no other codes, My scanner will not pick-up any codes when it doe's this. It's a 2001 1/2.
  10. There you go,,,,,Mikes got you covered. (As Usual)
  11. On my wheels, just like you have pictured, they are 24mm, Sorry no pix. The center of the lugnut is hollow looking. If that makes any sence:2cents:. hope this helps. ---------- Post added at 05:12 PM ---------- Previous post was at 04:57 PM ---------- just mesured with lugnuts on wheel, It was at 7/8'',,, from seated on the rim to the top of the nut, If you need anymore info I can take one off. I'm thinking as mike said, they are diff.
  12. Real sure it's aftermarket, I ordered my truck, and there was nothing in wood grain that i could of ordered. Love the look, stoped by a truck outfitter and they could order 5-6 diff woods, very pricey (appx 400.00/500.00) for the kit, After getting over the sticker shock I went back to order the kit. They looked for about 1/2 hour and found out they could no longer get them....GOOD LUCK,,If you find a place to get/order one please let me know,Later Ed.
  13. Took mine out and put it back-in, atleast 1/2 dozen times, Could not hear any diff, (but my hearing isn't to good:thumbup2:) So the way I see it,,,,, is,,,,,ANYTHING, that smooths / cut's tublance in the incoming air is a good thing:smart:...................Mines staying in:thumbup2:
  14. Grid Heater is cycling, Voltage drops, than when cycling is complete it's back around 14volt.Thanks,,, I'll clear the code again to be sure. thanks again.................
  15. Yes, I put a set of alum's off an older 1977 chevy on mine, would of left them on but the back spacing was off and they were 16.5's,,,,,,,,,,Hope this helps.Ed.
  16. Sorry to Hi-Jack the thread,, But been thinking the same thing, After Mike installed his and has a good report on the 275's without affecting the MPG looks like a nice upgrade; j-kidd or some other site vendor please shoot me a PM on the price for a set........ Thanks Ed.
  17. Been throwing the low voltage (1488) code, the batteries are new and the cables are clean and tight.Anyone have an idea where i need to look/go next to find the problem???The truck seems to run ok, Just like to find the problem so I can fix-it.Thanks Ed.
  18. Yes,, my fuel pressure is atleast 1-psi lower than it was before the new, (rebuilt) vp-44.I paid close attenion to the pressures,, before and after.
  19. Well its on and running:hyper:There is a noticeable difference, Lot's more power, No more code's (216):thumb1:Truck is quite abit smoother, Don't rattle as much, (this could be me)....................The fuel pressure is at 1 to 1 1/2 psilower than it was, Going to replace the almost new fuel filter, Just to see if thats it.Still at 12psi lowside,, was at 13/14, High was 16-18. Now 15-17.Thanks,,,,JKIDD.Later Ed
  20. Thanks for the offer, But I'll pass.Later Ed.
  21. Very understandable, I have a Moroso kit that comes with hardware for both header collectors. (for my gas 528") It just got me thinking, thay (both) wount hardly suck hard enought to hold a dollar bill aganist the hose, Im not ruling it out, Just say you use your set up with a little twist, As the tube comes up (in front of engine) and down along side the valve cover, THAN,,,, down the pass-side and weld it,, 3-4 feet down from the turbo:smart:,,,, My thinking,,,, the only problem might be the blow-by... More with a diesel, and my other concern was the Turbo with its force....These things (the kit),,(on a gasser) just dont pull that much vacuum, Just enought to keep the crank case from seeing pressure. Like I said,,, just thinking out of the box. On another note you would only use one on the diesel, insted of the two made for the gassers..........I can also see the problem by using the Turbo as a vacuum pump, (way to much).Just trying to figure all the possable draw backs.
  22. YA,,it plugs into the map/ecm, Mines been on for 3-years and I really like it.All the power I need, I don't need all the other Performance stuff..(on motor)
  23. What's your guy's opinon on a evac/system that plums/plugs into the exhaust?Just thinking,,, (like the gassers use) they dont seem to pull hard enought to suck oil out, plus they have a check valve on them. Just thinking out of the box.........
  24. What are you guy's running?Mine is straight piped, Looking to making it A little more quiet,would like to cut the noise. But not close to stock. 4'' in 4'' out, looking for something that sounds powerfull,,,What brands/cost/SS or not. Thanks In Advance....
  25. I :rolleyes:have to confess,,,,, A good friend stoped by,(i wasn't quite ready yet) Got to talking about it over a cold one, He said,,,, hell i'v done two of them, nothing to it:hyper: My response was have at-it, I handed tools,, he started at 4:30 and 5:15 HANDED ME THE PUMP.....
