2001 24v Cummins High Idle Issue
When you saw a consistent 5 volts at the IAT, were you using the black/tan wire for ground, or were providing a remote ground? - John
I have never experienced this, but I have heard of it happening. The general consensus is that a strong static charge builds from the normal operation of the serpentine belt. That static charge discharges periodically near the crank pulley because the crank pulley has the shortest air gap distance to ground. Some have replaced the serpentine belt with a different brand and said that it cured the issue. Others have said that the sparking causes no harm and have done nothing to stop it. - John I don't think it is that simple. The ECM could be putting out a good 5 volt supply, but an erratic ground could make it look like an erratic 5 volt supply. I would try to figure it out - not bypass it. - John
Have you checked for any trouble codes? The oil pressure switch, camshaft position sensor, and the manifold absolute pressure sensor all receive a 5 volt signal from the ECM. Splice #165 (S165) is a through connection for ground for all of these sensors and oil pressure switch. Since voltage is "all over the place" for some of these sensors, I would be checking the source and ground for the 5 volt supply. - John
Throttle stutter/truck jerks at highway speeds
Does your tuner read fuel pressure - commanded pressure and actual pressure? If so, what is happening with these pressures when the stutter issue occurs? Does the stutter between 1800 rpm and 2100 at any engine load, or a particular engine load? There are people on this site that know more about the common rail fuel system than I do - maybe you will hear from them. Sounds like you know your truck pretty well. Now that you mention operating the truck in the salt belt, I would definitely check wiring and wiring connections to sensors, ECM, frame grounds and body grounds, etc. How about the possibility of bad fuel? Might be worth a fuel filter change which would allow you to inspect the fuel passing through the filter, as well. - John
Have you checked for any DTC's? Is fuel pressure where should be (lift pump pressure)? What are the conditions of your battery cables (including the crossover cable) and battery connections - both positive and negative? You may want to get the tuner completely out of the system to help diagnose. Please give some history about the truck - miles and years you have owned it and what you have done to it, etc. - John
4.11 Rear end
What tire size are you running? - John
High EGTs After Minor Upgrades
That makes sense regarding the 9 cm2 housing and could very well be his problem. - John
What was the engine rpm and boost pressure when the EGT reached 1500°? I presume your observations were done with an empty truck. I am curious as to why the high EGT's. I always thought that the HE351CW turbo was a good upgrade - just what I have read. - John
1997 2500 T Steering swap
I agree, the concept seems sound. If the added bearing is centered and well anchored, then it should be beneficial. It seems like you may have the equipment and the skills to do that. Let us know how it turns out if you decide to make the modification. - John
Torque converter install.
I haven't done your particular job, but I think you have to line up two items - the splined input shaft and the tabs (or cutouts) for the pump. Usually the shaft engages first (could be the opposite), then you need rotate the converter (with no axial pressure) to find the tabs for the pump engagement. Just an educated guess. - John
With stock sized / near stock sized tires and stock suspension height - I say no. I am not sure that there would be any benefit even with bigger tires and raised suspension. I installed a steering brace years ago and I have since removed it. The one thing that bothered me about the steering brace was that there were only two set screws (90° apart) for centering the bearing on the the Pitman shaft. That never made sense to me - it always forced the bearing to one side which in turn forced the Pitman shaft to one side, and the set screws would never stay tight. That did made sense to me. I would think that three set screws at 120° apart would have allowed for accurately centering the bearing and would have kept the set screws tight. - John
5v reference circuit? Ecu? All of the problems!
Sounds like you have your work cut out for you. Just be patient and correct all of the previous owner's careless wiring. Chances are that there is nothing wrong with the expensive components - just poor electrical connections to them. Let us know when you get the problem resolved. - John
Intermittent dead pedal and hesitation
Keep us posted...., - John
To aid in troubleshooting, it may be worth your while to remove the Quadzilla completely from the system for awhile - at least until you get this problem resolved. The Cummins sensors are very reliable. In fact, I still have all of the original sensors in operation on my truck. You said that you were going to check for codes with a Snapon scanner after you put the pump back in. Has that been done? - John
Since all of your codes point to a 5 volt supply issue, I would definitely check out the 5 volt supply and ground. Also, I would check the supply voltage and ground for the ECM and look over the general condition of the electrical system (battery terminals, cross over cable, grounds, etc.) Splice 165 (a problematic splice) is part of the grounding circuit for the ECM and other sensor grounds of the 5v system. Auto Computer Specialists (look in the Vendors section on this site) rebuilds ECMs . New ECMs are not available. Lift pump cycles 1/4 second with key in "run" position, approximately 25 seconds in "bump start" position. Just round numbers. - John
Alternator failures
No fuse, but you can simply disconnect the two heavy wires that feed each intake heater. Disconnect them at the positive terminal on the driver side battery. I will repeat what I said in one of my previous posts, "The Bosch and Denso alternators are of excellent quality." The same goes for the Denso Starters. Unfortunately, many people don't realize the value of these OEM alternators and starters in terms of a long dependable life. The first sign of an electrical problem has them purchasing a cheaper re-manufactured alternator or starter from a chain auto parts store. From there, it usually goes downhill. Those re-manufactured components are usually of mediocre quality at best. The worst part of the transaction is that the truck owner is giving up a quality component in trade for a not-so-quality component under the guise of "lifetime warranty". So, either one of two things are happening in your case. You are getting poorly re-manufactured alternators, or you have a serious electrical problem that needs to be addressed. I would recommend checking the condition of all your battery connections - positive and negative. And, check the condition of the crossover cable. Just because an electrical connection is tight does not mean that the connection is good electrically. There could be corrosion that is not visible until the connection is taken apart. - John
Have you used a quality scanner for checking codes? Not all scanners are equal. Or, have you used the ignition key method to read codes in the odometer? - John Since your problem is intermittent, it is possible that the pump could be defective and still pass the test. Don't dwell on this, but don't disregard it, either. Have you re-checked your work related to the W-T wiring modification? - John
2000 Cummins Surge/Dead Pedal
I would do this step, first. It would be good to know whether or not a false signal is being generated at idle. Since the DTC states, "Idle Validation Signals Both Low Problem detected with idle validation circuits within APPS", I would double check the wiring condition and connections from the ECM to the APPS - and, maybe try another APPS, if you have one available. Also, I believe that you said you did the W-T wiring modification. If so, re-check your work regarding Splice #165 - the ground for the APPS, ECM, and other sensors. - John
P0222 (M) Idle Validation Signals Both Low Problem detected with idle validation circuits within APPS. I would definitely find out why you are getting this code. If the ECM does not get a signal for idle validation, then the engine rpms will not go to idle. Which APPS are you using now - OEM or TImbo? Either way, you could try adjusting the mechanical stop where the APPS is located in the engine compartment. Back it off an extra distance to ensure the throttle will activate the idle validation switch that is built into the APPS. I seriously doubt that. An injector misfiring would likely cause a miss or a timing knock. Engine oil feeding a cylinder wouldn't allow the engine to shut off immediately when you switched off the ignition. I think the P0222 in telling you something. Double check all of the pin conditions in the connector to the APPS. - John
Alternator failures
I just used a switch that I had laying around. A push button momentary switch would work well. Place it where it is convenient to use. The switch can be light duty, as it only operates the coil portion of the intake heater relays (less than 500 milliamps of current). I disconnected terminal # 1 (OR/BK wire) on relay # 2 and terminal # 3 (YL/BK wire) on relay # 1. I sealed and taped the ends to protect them for future use. I provided a light gauge wire (18 gauge) from an unswitched source, through a 5 amp fuse, and then to the momentary control switch. From this switch, I continued with the 18 gauge wire to the coils of both intake heater relays. Wired this way does set DTC P0380 and P0382, but it does not illuminate the MIL. From this point on, you can be the boss and use the intake heaters when you feel it is necessary. The ECM controls when the intake heaters operate. If the ambient air temperature falls below 60° F, then the ECM will command both intake heaters to operate for a determined amount of time when the ignition switch is turned on. After the engine is started, the ECM will cycle the intake heaters (one at a time alternately - called post cycling) until either the vehicle speed exceeds 20-25 mph, or engine coolant temperature reaches a specific value. The air intake heaters exist primarily for emissions and occasionally they are needed to assist in starting a very cold engine. - John
Alternator failures
Give us some repair history on your electrical system. How old are the batteries? Have you verified that all battery and ground connections are good? How about the crossover cable? Have you done the W-T wiring modification? OEM wiring charges the driver side battery - the W-T wiring modification charges the passenger side battery. I personally don't trust over-the-counter re-manufactured electrical parts. They can be problematic regarding quality. If I wanted an alternator or starter rebuilt, I would use a quality Auto Electrical shop in the vicinity. The Bosch and Denso alternators are of excellent quality. The Bosch alternator (the original still controlled by the PCM) on my truck is pushing 400,000 miles with only replacing alternator bearings and brushes. When you do replace this alternator (I think you already have), be sure to monitor voltage at both batteries, don't just rely on the dash voltmeter. I would disconnect the grid intake heaters temporarily just to help with the diagnosis. It is not necessary to take any of these precautions. Even when you do plug it in overnight, the grid heaters will still post cycle for a period of time after the engine is started. A new Bosch or Denso alternator will easily last 200,000 miles under these conditions. Even though it is not necessary, I have installed a manual momentary switch to operate the grid heaters on my truck. I did this to reduce the electrical load on the alternator and because grid heater operation isn't necessary 90 per cent of the time for starting the truck, or for post cycling after the engine is running. - John
Hunting at idle when in gear
Before replacing the APPS, you wrote: After replacing the APPS with a Timbo unit, you wrote: Has the "skipping and bucking" disappeared? What horse power injectors are you using? As @Great work! mentioned, high horse power injectors can cause hunting. Different torque converters can apply different engine loads when the transmission is placed into gear. - John
ECM Advice
Great detail on your reply. Another thought. Have you tried using the key switch to read codes in the odometer display? 2001 is a questionable year for using the key switch to read certain codes. Some 2001 models read the PCU only, and other models read PCU and ECU. If your truck happens to read both, maybe you can see the companion code in the ECU. If your truck shows both, just be sure to be patient and wait for both PCU and ECU to say "DONE". Regardless, it does seem there is a hidden ECU code that needs to be seen. Just don't know how to get there. - John
Another bad VP?
Do you know if your VP44 pumps were refurbished - as in a new PSG vs. refurbished PSG, and was the pump run and the PSG calibrated to the pump on the Bosch 815 test stand? - John
ECM Advice
On this ECM, you say "truck runs". Does this mean everything is normal and the truck runs good? Just a 1693 code? Does the code set the MIL (Malfunction Indicator Lamp)? This could be normal lift pump voltage while the engine is cranking. The ECM reduces voltage to the lift pump by using pulse width modulation during engine cranking to prevent possible hard starts under heat-soaked startups. The ECM supplies full voltage to the lift pump after the engine is running. Is you lift pump fuel system completely stock? Does the ECM drive the lift pump directly? - John
