Tractorman
  1. Just shooting in the dark here, but what about using a resistor (if possible) in the coolant temperature circuit to fool the ECM into thinking the coolant is above 132° when you start the engine. Might help to confirm what you are already thinking. It is a rather odd situation that you have here. Once the ECM detects a timing issue, the ECM is de-rating the engine power. This is normal. Just odd that it happens at a very specific coolant temperature. - John
  2. @JAG1, I think no earlier than the middle of May for camping, but definitely before the Memorial Day weekend. The lake elevation is at 5,000 feet. There will likely be leftover winter snowfields around in April, plus downed trees may still be laying across the road from winter storms. The photo is from Google Earth Street View in April, 2012. I will take a trip over in mid April to see how things look. It does appear the road is a paved road all the way to the lake - just a single lane. - John
  3. Hairsprings are hard to find. I can't imagine trying to find a hairspring hole. - John
  4. @JAG1, you can count me in. As I mentioned before, I will scout the area beforehand to make sure the road is clear for access to the site. - John
  5. When I rake up my leaves, I don't put them under the hood like @LorenSdoes. - John
  6. Does the hose fitting look like this? If so, the o-ring slides up against the flare. The nut seats the flare for metal to metal contact. The o-ring gets about 10% compression for a positive seal. You probably have the correct o-ring. You could be over thinking it...., - John
  7. I am ignorant here - why can't you use Oxy / Acetylene? You have such an amazing amount of history in your neighborhood! - John
  8. I am not sure of what you are describing. Most circuit breakers use a conductor with terminals at both ends. The conductor and the terminals will be surrounded by a non-conductive material (plastic, composite, etc). Is this what you are describing? If so, there is nothing wrong here. Post a photo of the circuit breaker. - John
  9. It seems that when you reset the APPS, the symptoms go away for awhile. That is indicative of an electrical problem. If strays signals interfere with APPS output, the ECM will ignore the stray signals for awhile, but if they don't go away, the ECM will eventually treat the stray signals as valid. I would recheck your work that you did when you performed the W-T wiring modification - especially the ground circuits for the ECM and PCM. Is there any accessory that has been added to your truck that could give off strong electrical fields? - John
  10. Try locking out Overdrive (4th) and see how it behaves. The torque converter may locking and unlocking in 3rd gear. Tthat combination, plus the shift into overdrive, may be masking the symptom. - John
  11. There are two types of grinding that can occur. * when starter gear teeth and flywheel teeth don't mesh - a full inspection of the flywheel ring gear must be done to eliminate the possibility of any damaged teeth. This means barring the engine over for 360°. * when the starter drive gear clutch slips - usually first occurs in cold weather. The starter must be replaced with a quality starter. The OEM Denso starter is a quality component (along with the Denso and Bosch alternators). On my personal truck I have installed two starter contact kits. About 65,000 miles ago, I took the starter to Lazer Auto Electric (near Salem, OR) and had them turn the commutator, replace two bearings, and solder in new brushes - all for $50. So, 370,000 miles later, I am still using the OEM starter. All of my starter repairs were done from a preventative maintenance point of view - there was never a starter failure. What were the symptoms with the starter that you replaced? - John
  12. I, too, purchased a radiator from Napa - $220.00 at the time. Almost four years and over 60,000 miles and still serving me well. Original radiator lasted for 308,000 miles. One of the side tank seals started a slow leak. - John
  13. Yup, fasteners are a "fastenating" subject. - John
  14. Not trying to second guess you here as I don't know what size they are, but there is a Torx 27 tool size as well. It would be easy to think a Torx 25 would be the correct tool. It might be worth double checking. - John
  15. Did you perform all of this work in one time frame? In other words, did you pull the engine, do all of the work, and never run the engine until the work was completed? If so, that leaves a lot of possibilities as where the problem lies. If you performed the work differently, break it down into events and let us know how you proceeded. Is this symptom still present? If you purchased Bosch RV275 injectors (ending in part number 635, not knock-offs), I really doubt the injectors are the problem. By the way, I installed RV275 injectors in my engine over 65,000 miles ago. They idle very smooth. @hdpwipmonkey and @weissguy01, when your crank position sensor failed (no tach signal), did it affect the engine idle? If it did, were the symptoms the same as @Reaper22's? - John
  16. @W-T, what a great troubleshooting technique! Such a simple and reliable method to test a DC motor! I do have one thing to add. I looked up the word "wench" . So, for those of you who have a wench on your front bumper AND have a significant other, the two may not mix. Be careful - especially if you hook up electricity to her. You can disregard if you have a winch on your front bumper. - John
  17. Yup, you've been busted. Shame on you! Uh....? I guess I should install mine, too. - John
  18. It is quite possible that what you are saying is true. You just won't know until you have a voltmeter attached to one of the batteries when the situation occurs. If the PCM does turn off the alternator under those conditions, it could be normal - the PCM could be protecting the alternator by stopping unusual current flow under an abnormally low voltage condition. Only a guess. - John
  19. I don't know. The only way to really know is by having a multi-meter connected to one of the batteries to measure voltage while the winch is under a load as you described earlier. This is one thing that I don't really care for regarding computers - they can be programmed in many ways to perform certain tasks under varying conditions. If you aren't privy to the program's instructions, you are not going to know what will happen under certain conditions. It could be that the alternator is still charging, but the voltmeter in the dash has been instructed to turn off when battery voltage drops to a certain threshold. Just don't know. Reading battery voltage at either battery with a multi-meter won't lie, it will tell you if the alternator is charging immediately when you stop the winch operation. - John
  20. The dash voltage gauge is fine to use for general reference, but it is not a reliable diagnostic tool. A voltage reading at each battery will tell the story. When winching current well exceeds charging current for 30 seconds at a time doesn't mean the alternator has quit charging (indicated by dash voltmeter). A voltmeter at the batteries will immediately show rising voltage when the winch is turned off if the alternator is charging. The dash voltmeter may / will not. - John
  21. First, I commend you on having a proper setup for winching, and for you giving a great description of your symptoms! When batteries and a charging system are tested to the limit (winching will do that), then the smallest inefficiencies of the electrical system can come into play. To help with figuring this out, more information is needed - mainly two factors. Was the engine at idle? Do you know the maximum current rating of the winch? Other things that could cause the symptoms: * The batteries (even though they are new) need to be at a fully charged capacity just prior to winching. * The alternator could be at fault (charging at reduced capacity) Alternator output can easily be checked at a good auto / electric shop * The heavy cable and cable connections (even though they are new and routed properly) could have one poor connection. Think of it this way - every battery cable has four connections. Example (using the battery crossover cable): passenger side battery to clamp, clamp to passenger side cable wire, cable wire to driver side clamp, and finally clamp to driver side battery. So, one wire - four connections. Multiply that by number of cables used means a heck of a lot of connections. Something that I always remind myself - an electrical system can only perform at the level of its worst connection. It only takes one poor connection to dramatically reduce performance - especially under heavy electrical load. I recommend hooking up your winch to a heavy continuous load. With a helper operating the winch, use your voltmeter to check voltage at each battery and relevant connection points while under load. - John
  22. It is not full My Inbox shows, "Used 0% messenger storage" and "storing 5 messages (max 1000)." So, I am not sure exactly what is going on. - John
  23. Thanks @Mopar1973Man. I contacted Dynamic Transmission via email a couple of hours ago. They seem to be the unanimous "go to" transmission place. - John
  24. Thank you @IBMobile, we may be moving forward with this re-builder. I just talked to my brother-in-law about the Stage II transmission from Dynamic Transmission. He has determined that he will likely be keeping the truck, so this transmission would be a good match for his needs. - John
