Collinst15
Everything posted by Collinst15
  1. It is the style were I can adjust the FP - I adjusted it about a month ago and set it for 17-18spi at idle. Ill make sure the jamb nut is tight this weekend. Tim
  2. dripley, The pump is just over 1 year old. I installed it 12/2017 and this is my only issue with it thus far. I am going to park it until I can check volts this weekend. It is just odd that the psi would differ 2 psi running and not running. I don't want to hurt 6 month old vp44 with lackluster fuel pressure or dirty fuel. Tim
  3. Good afternoon, I have a quick fuel pressure question. I recently noticed that my FP gauge reads between 14-14.5 psi while driving, it was reading 17psi-18psi a few weeks go. I assumed that the filters may need replacing, although they only have 2500 miles on them if that. I have not swapped filters out as of yet, but noticed something odd today. I bumped the engine over and FP gauge showed 16psi, but when I fired truck up the gauge would fall to 14ish psi. Would the VP44 drawing fuel cause the gauge to drop. I have adjusted the Airdog 4G in the past to show the 17-18spi while running. the gauge "T" with sensor is approx 20 inches away from VP44. I just think it is odd that a few weeks ago fuel pressure was good and the past few days it has dropped and that there is a drop when engine is running compared to when Airdog is solely running. Any help is appreciated. I have not checked voltage at the pump yet, plan to hopefully this weekend. Tim
  4. Hope your recovery is quick and everything works out! This site has taught me a lot about the 24v Cummins motor.
  5. Thanks guys! ill give DAP a call in the morning! Tim
  6. Thanks guys. I priced all the parts using Cummins/Mopar part numbers and the price is over $250. Was looking for ideas to make the system for cheaper but still be reliable and not leak. Tim
  7. Good evening, I have a 1999 Dodge 24v and am looking at replacing the fuel return system. Has anyone made their own return system? If so, do you have a list of parts used? I may just buy stock parts, but would like other opinions. I am looking at replacing the line at the back of the head, line from vp and the t fitting. The return line going to the tank is in good condition and does not need replacing. The other lines are rusting and starting to leak. Thanks, Tim
  8. Thanks for the info. If I can get it for a good price I may jump on it. Tim
  9. Good evening, I have a chance to buy a used Quadzilla Adrenaline V1. Was wondering if I could update it to V2 tuning? If so, how? It comes with control pad and the old black display screen also. Thanks, Tim
  10. Oh, that looks like a good size! Saving my money to get the quad hopefully at beginning of year. Any info in a release date for monitor?
  11. John, Truck has a 4in diamond eye exhaust with muffler. It's just loud, but I like it that way.
  12. Here is a video of my 1999. It has173k miles. I have to admit I have to turn truck off at drive-thrus because it is loud and I cant hear person in speaker. 20181020_072301.mp4
  13. I dont have any big busy places around me, so I am stuck with local convenience store diesel. Last year I used power service anti gel every other tank, but that was with a 170k miles vp44 and don't want to add anything that will reduce lubricity this winter. I dont have grid heaters either. Tim
  14. I thought I noticed a slight sound difference also. Another quick question, mopar1973man, what do you use for antigen with the 2 stroke oil? I live in CNY and wanna make sure my fuel doesn't get but also dont want to add anything that will harm vp44. Tim
  15. Here is a picture of my 1999 with 3in black nerd bars I picked up on the cheap.
  16. Perfect Thanks! I don't want to ruin the VP44. Was a pretty penny and was not expecting when it died earlier this year. Tim
  17. I have not had grid heaters since spring. I removed the harness when my relays died. I am going to adjust the FP up this weekend. Would 18psi at idle be okay?
  18. Thanks guys. I have noticed prior to yesterday that with my quad xzt+ turned on performance mode the FP will hit 13 to 14 if I'm WOT so I was going to increase it a little anyways, but wanted to see if adding 2 stroke would cause a change in fp. Tim
  19. Good morning everyone, Yesterday I started using 2 stroke oil at fill up. I have a reman vp44 from T-bred with 1000 miles and been reading 2 stroke oil is the way to go for pump longevity. After I filled up I noticed my FP was at 14.5ish lbs compared to the 15lbs it was at before adding the 2 stroke oil. Is this normal? Has anyone else seen this? I have an Airdog 4g lift pump so I'll just increase the pressure tomorrow but thought it was odd my fp would drop. Tim
  20. I removed it bc the solenoids needed to be replaced, I bought new solenoids and now can't find harness. I'll look into making my own. Thanks Tim
  21. Good morning, I am not sure this is proper place to post, but does anyone know where I can get a grid heater harness for my 1999. I took my off this past spring and I cant find it and want to hook up the grid heater for winter. Tim
  22. I am not sure if injectors are stock. I see 1100-1200 if I get into it. My hx35 maxes out at 20psi boost. I know previous owner did nothing to truck, but idk what owner before them did, if anything to motor. Tim
  23. I have a xzt+ on my truck. I like the power, but egts get warm. I'll be up grading to the adrenaline next year. Tim
  24. 1999 with 170k. Work truck and daily driver.
  25. Thanks guys. I wasn't going to get them for my truck due to reviews. Just looking out for my father in law. Thanks Tim
