02cummins25mpg
Everything posted by 02cummins25mpg
  1. Been a little busy this year. Haven't put over 1K miles on the 02 Dodge this year since I bought and started driving commercially a 2002 Ford E350 7.3 PSD 3.55. This year I have driven 112,325 miles using 5,870.389 Gallons of fuel for an average of 19.134 MPG. Average cost of fuel was 3.902 per gallon. I am by nature a conservative driver, most of the time with the cruise set at 60-62. These totals include one trip I pulled a tall heavy trailer from AR through TX to AZ and then back. Averaged 12 MPG for about 4K miles on that trip. 3.55 gear SUCKS pulling with a PSD. Totally different torque range. If I could figure out how to install the cummins in the van then I would have something...LOL
  2. I had this conversation with someone just a day or two ago. My buddy had a new Charger and he could not mess with the navigation while the car was in gear. And I hate government intervention also. But make it where a cell phone wont work when the vehicle is in drive. Just my .
  3. LOL... I just wanted to be like Mikey. He stuck a stick in and stopped his.. It's not locked up but it is really tight. This was replaced in the last 4 months. Wish I hadn't throw the old one away.:banghead: Wondering if in the cold weather I could take it off and see if my mileage came back up. Any thoughts on removing the fan in cold weather??
  4. I will be glad to swap fans with the Guru...:lmao:I was hoping he would chime in...
  5. Any ideas how to loosen up the fan clutch???
  6. Been trying to get back to the really good mpg's that I got about a year ago. In the last 6 months or so have installed new injectors, found a boost leak, and replaced the fan clutch. Truck runs better, has more seat of the pants power, but still cant get back to the 24-25 mpg --- Update to the previous post... I believe the fan is spinning all of the time. I know I can hear it when I take off. Could be the fan I hear or the fan causing the motor to work harder causing more boost:shrug:
  7. Last week went on an 1100 mile trip, 90% interstate, @ 60-65 on cruise and only got 17.9. Could here the turbo the whole time. I knew it was working too hard to just be cruising down the interstate. I was thinking about removing and cleaning the I/C. Then I saw that video and thought that might be my problem. If I cant figure out how to loosen it up the fan may end up in the toolbox.
  8. if I try to spin mine it will only go MAYBE a 1/4 of a turn.
  9. Replaced the fan clutch over the summer and have noticed a drop in fuel milage. Saw the video of Mike stopping his fan, got me to wondering, so I went and checked mine same as Mike. Chewed the end off a 2 x 4. Question is how do you loosen one up? It is not frozen up it is just really tight causing the fan to be under load all of the time...
  10. 5 & 6 aren't bad. It's the fuel lines to the pump that made me throw things....LOL
  11. Been there done that..... 30 minutes ago....
  12. I want to publicly thank you Mike for this forum and all the work you have put into it. I have needed to change the injectors in my truck for about a year and a half but I could not ever get enough ahead to make that happen at a shop (1200$). After ready this forum and studying as much as possible all the procedures I said screw it I am gonna do it myself!!!! Took me about 5 hours but I was quite happy that I managed to do it myself and it would not have been possible without this forum and all the members..THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:):)
  13. THanks, was out there with a strap trying to get the two pieces to hold together while I got the clamp on. Would not seat properly and stay to get the clamp on and tight...Think I have it now:pray:
  14. There is a piece of cast aluminum that clamps to the intercooler pipe. Where that piece connects to the turbo. Is it supposed to be a gasket or an o-ring? Been outside playing with it, think I got the leak stopped but I was thinking it had an orange rubber gasket and all I saw was an o-ring....Hope the rest of the gasket if there was one isn't in the I/C..
  15. My turbo is leaking air underneath at the connection after the elbow!!!! Any one know what the part # or if I can get this gasket at one of the national parts stores. Thanks in advance...
  16. sounds good to me I was just throwing that out as a thought in my warped little mind!!!!
  17. Increase the efficency of the engine, ie more air in more air out mpg will go up..
  18. http://www.ityre.com/en/tyres/catalog/ilverstone/size/132463/
  19. Lets see if I can get some more thoughts... I hardly ever pull a trailer with this truck any more. Been reading up on water/meth inj.. What if I ran the turbo over the top straight in with a 50/50 meth...Quicker spooling? Better mpg? Any thoughts?
  20. That would definitely require much data with way too many variables...LOL Boils down to I got a good one:hyper::hyper::hyper::hyper:
  21. I have had several cummins and one duramax but this truck is the best for mileage.. Not the strongest but good enough..Worst was one of the first 6.7...Dodge bought it back....Hated that truck..LOL
  22. I will admit that I drive trying to get the best mileage. But as you can see the bed cover is higher than the cab and bang heavy. Truck rides better but it has to use more fuel with it. I would love to see what THIS truck could get with tuner, injectors, etc. I had an 06 dually that would not get better than 17 ever..go figure.. --- Update to the previous post... I wish.........
  23. My old beater..Love that truck...LOL
  24. Yeah, I am not complaining but really I am scared to do anything to cuz it might screw it up...LOL55=24+ Dont really see a drop in the winter. No chip or injectors. Stock. No overhead.
  25. Straight pipe does get on your nerves after awhile...leave the resonator on...
