int3man
Everything posted by int3man
  1. Boy I thought that I was really loosing it. I read the Parallel Battery wires and Didn't remember a thing about them. I just put a real terminal on my 2/0 that runs over the radiator. Michael
  2. If you have an android phone or access to one you can connect wirelessly and download the app. I use this one and Mopar1973Man suggestion. Works great. Best $50 spent! https://www.amazon.com/ScanTool-OBDLink-Bluetooth-Professional-Diagnostics/dp/B00H9S71LW/ref=sr_1_11?crid=3UBQURE97AMH0&keywords=bluetooth+obdii+scanner&qid=1563631324&s=gateway&sprefix=bluetooth+ODBII%2Caps%2C217&sr=8-11 Good Luck. If the PCM has been flashed 7 times maybe something is causing it to go bad? Michael
  3. No fun is when you spend a week in freezing weather, out doors, troubleshooting your nephews Toyota Station wagon. Only to finally learn that the Fuel Pump relay gets it's power from the Rear Defroster fuse. That was a chore. Michael
  4. O.K. Fully charged Batteries. Truck running 14-19 amps 13.9 volts. A.C. on Max 33 amps 13.9 volts Brake lights No A.C. 23 amps 13.9 volts. So I have to agree with Mopar1973Man that too high of a heat area, in front of the battery. I will be carrying tools so that I can bypass circuit breaker in the future. And if it continues to false trip I'll replace it with a Brand name Chinese Resettable circuit breaker!! Thanks Michael
  5. Hi All, So truck no start this morning. I put the trickle charger on it (10 Amps) and went off in the wife's car. Came home and it was still sucking down 3 amps. Found the clamp-on Amp meter and fired up the truck. At idle the Alternator was putting 23 amps out. Turned on the AC to Max and output jumped to 46 amps. Still short of the 150 amps that is tripping the breaker. So I'm going to extend the wires to the Clamp on so that I can drive the truck and measure the Amp output. Drive the truck and see what is what. Any other suggestions? Michael Oh the Test stand did not have an amp meter it just reported the min / max voltage dumped into a carbon load I assume. Alt Bad Ground: Voltmeter has never indicated an issue until this event. rock solid. I have a Phone charger that is also a Digital volt meter that runs the Quadzilla tablet. Always 13.9 +.
  6. That is what the test stand reported. I looked over his shoulder. Michael
  7. Looks like the same manufacture!!! https://www.amazon.com/ANJOSHI-20A-300A-Waterproof-Inverter-12V-36VDC/dp/B07H9W7QBV/ref=cm_cr_arp_d_product_top?ie=UTF8 I went with waterproof.
  8. Well Crap Amazon Orders history only goes back to the first of the year. Well I needed something to do tomorrow! Ah Haw Search engine found it December 2018. Thanks Michael
  9. Thanks but this guy will make the ends an Crimp and heat shrink them for me. I need exact lengths and hole size for the Lugs. Michael
  10. Hi Mike, Did that this morning. Alt is fine puts out to 15.6 volts. Might be cheap Chinese Circuit breaker? It was an amazon find. I can always bypass it and see if anything starts to smoke!!! Naw I have a clamp on Amp meter just have to find it! Michael
  11. Well the plot thickens. Got the Alt reinstalled and moved the circuit breaker to behind the battery. Drove it to the post office and dinner. On the way home I looked and again no voltage. Sure enough the breaker was tripped again. So time to find the Clamp on Amp meter and see what the --ll is going on. I've been running the AC on Max but I have done that since I have owned the truck. As WT pointed out its hot in the Central Valley!!! Michael
  12. Hello and Help. Does anyone have the length for all the battery cables. Eyelet size would be a nice bonus!! Battery + cross radiator to Battery + Starter to + Battery Driver Battery to Ground Passenger Battery to Ground Thanks! Michael
  13. Alt tested fine. Well it must be a heat thing, with the AC running raising all the temps. I'll move the CB to the back side of the battery and put the Alt back on. Batteries were 11.88 and 11.89 . So now it appears that it is BOACB time (Break Out Another Couple of Benjamin's time.). Time to replace the battery cables, I did the battery terminals when I bought it. Never been a big fan of friction clamps. Mike do you have lengths and eye sizes listed somewhere? I would like to order them prior to replacing them. I have a customer that owes me one, and has some 00 Marine cable that he bought couple thousand feet of. Thanks Michael
  14. Yup as usual your are correct sir. As soon as the breaker trips the voltage goes down! As to the heat it is 2 miles from the house to the post office where it first happened. I'll pull the ALT and Volt meter the 1 year old batteries, no strap. Michael
  15. I'm going to pull the ALT in the AM. Thermal Tripping breaker doesn't explain the lowering voltage. Breakers are made or not; not a slow decay. I'll report tomorrow. Michael
  16. Hi Mike, I went one better on the mounting location and mounted it on the front battery support passenger side. I'll pull the battery but wanted to be sure no in truck tests before hand. I'll pull it in the morning when it is 64 outside, and the alt is the same. Michael
  17. Hi Guys, O.K. WT modification and did the 150 Amp circuit breaker modification 6 months ago followed up with the Fuse in the field wire. Got in the truck and drove to the post office 98 deg. AC on full. Come out of the post office and cell phone charger is flashing Low voltage. Volt meter is to 0. Stop get out and reset the circuit breaker, it had tripped. Get on to freeway and drive to next town for dentist app. Bam the voltage drops to 0. Pull over after getting off the freeway, reset circuit breaker. Turn off the AC, roll the windows down. Start Truck and we get 14 volts. Drive for a bit and the Faulty gauge idiot light comes on, still haven't fixed the oil pressure sending unit. 90 seconds later the volt meter is diving. 12.5 12.3 12.1 Bam 0 Breaker reset. Made it home after the dentist. So did I blow a diode pack or what. This is a rebuilt Alt that has worked perfect until today. TIA Michael
  18. I'm going to stick with something that is controlled by a relay. If you look at the photo there is a clamping diode installed. Where does the Orange Wire go? Michael
  19. I just used some locktite and it seemed to seal. It was clean and dry though. There is no pressure per say Just atmospheric. Michael :- )
  20. And for the record. A thin Headed bolt. https://www.summitracing.com/parts/tff-6184b?seid=srese1&gclid=Cj0KCQjwpPHoBRC3ARIsALfx-_K7OTG3V36zRa9-d8PzCztCNTswvnysSr-s2NuQZTdMg-hsf8hKSQUaAkQnEALw_wcB I can sleep well tonight. Good luck with your Truck Power steering. Got a little off track. Michael :- )
  21. What he said, and it is not in the center of the pump as someone else mentioned. Michael :- )
  22. Chuck it up in a lathe, by the threads, and reduce the thickness of the hex head that protrudes from the part. For clearance purposes. I hope that makes sense. If you look at the JEGS picture that is a thin headed bolt shown. Michael :- )
  23. Just be careful you are probably fine in this application but I remember they were thin head for automotive applications. I just dug out my Challenger, to make a driver out if her. Having to beat he kids back with sticks. Paint has faded of the last 15 year but she is still there. 340 Auto with Power steering. Michael :- )
  24. Yea that's it, it is a thin headed bolt or a stud depending on the application. 440 used one configuration and the small blocks used a different one. Same pump different accessories / Bolts / Studs. Still used through 2002 cool. Michael :- )
  25. That's what I remember that's the bolt that holds the reservoir onto the pump. With out it the fluid leaks down to that point. Michael :- )
