OmahaGen2
Everything posted by OmahaGen2
  1. Okay well this is a wealth of information thank you to all that responded. I am going to do the Hot Wire test tonight, but I am not sure if that will define anything since it would idle previously. I am trying NOT to live in denial about the Inj Pump failure, but it is what it is & the truck sat a long time. I would be grateful for advice on changing out the entire system, I had planned on eliminating the OEM lift pump & the fuel filter/heater with a dual filter cartridge system, but any advise on what system has worked for others would be appreciated. I have been adding 2 stroke oil to the fuel. Anyone have any input on VP replacement? I would of course most likely lean towards a Bosch certified dealer, I find it interesting when places offer 1 year versus 2 yr warranties like Thorughbred (I read the electronic update, etc but come on guys) Thank you again..I will try to keep this project updated with pic's & progress. Thank you for the code responses, we have had 2 hail storms this season so I am very busy, but I am going to dig in and do it myself. Any suggestions on where to get a VP pump or Quadzilla?
  2. Ouch Based on codes? or Behavior? or both? just trying to follow along. TY
  3. Running fine, turn corner push to 1/4 throttle instantly dies coast to shoulder. Sits for about 10 min to give a once over. turn the key it rough idles for 2 min then smooths out. It continued to do this rough idle start & then smooth out. Towed it home. Changed fuel filter, hooked up my Smarty to read codes. (7) codes P0251 Fuel Inj pump fail (replaced lift pump 6 months ago carter) (I can hear it run when bumped) P0252 Inj pump fuel metering P1688 Internal fuel inj pump controller fail P0254 Fuel Inj pump mech fail fuel valve P1693 Generic fault indicating fault in bus or PCM/ECM interface P0602 Control module programming error P0122 TPS low voltage I have not done anything else since changing fuel filter, I would also note that the Smarty gave me definitions slightly dif to what I looked up online such as P1693 JTEC module detectedin companion something or other. Any words of wisdom before I run pump & fill the stock fuel filter system? Thank you.
  4. Thank you. All indicators I have including title check/car fax & seriously looking it over for tell-tale signs before buying the mileage is accurate. So you think I should change it from a Smarty3 tuner to a Quad (I assume you mean quadzilla) ? Everything I read about Tuners Smarty3 was the choice for best and/or practical mpg, etc. (Until I bought it & had it installed then I found 2 respected opinions mentioning the Quadzilla as a possible better choice. My list is so long now of wanted maintenance & upgrades. Dowel, electrical interference (converter lock), transfer case support (supposedly a mount that fits GM will work in a direct fit), cooling system bypass, transducer etc for the Tranny and on & on.
  5. Sorry for not getting this on here sooner..Only excuse: I'm a roofer, we had hail come through, been extremely busy. Here is what I know: Gears should be 4:10 (based on codes), I have a Smarty tuner set on 2, injectors I have zero clue, Automatic with Gear Vendor overdrive that I use every chance I can. I did add a S+B cold air intake & a Banks intake with the down tube, I changed out all battery/power & negative cables & cleaned up all grounds (I believe it was 7 total including the post under the battery box that had 13 corroded ground wires connected to one terminal it.) Installed a new Carter lift pump (temporary until I change the entire system. Wheels: I am running 2018 OEM 18", and let's see removed the BD exhaust brake was rusted shut, but I have it operating now & will reinstall. Let's see I removed the 3 piece driveshaft & carrier bearing & installed a one piece driveshaft.. Transmission gasket/flush, 4 KYB gas adjust shocks (which I like, but I'm, thinking the front coils need replaced) When I have time .S-.belt, water pump, belt tensioner, etc Blow by: Have tried the kettle test (no bounce at all) I had a local shop check it out when I first brought it home, said it needed nothing (I won't go there for now) I now have my gauges Fuel, EGT & boost. & will have them in over the next 2 weeks. I have a 10K bumper pull camper have only pulled 3 times campground & back (within a 100 mile radious) & I use it for work as of right now. I do not beat it at all, I did take it up to Black Hills last year & On the return trip I pulled a aluminum trailer with 2 motorcycles on it. I ran 80+ for about 600 miles & averaged out to 15.6 MPG My first Diesel & I want to add the this site as well as Mopar man helping other forum sites with info, I did it all myself & want to continue to do so. Big Thank you! Miles currently are 76K Ok with all that said, I am thinking it is time to change out the injectors as I suspect they are original. I am after 3 things, Mileage, Dependability & next winters paint job. Any suggestions on what injectors I should try? I will probably have the old ones tested. PS: this was only a test pic for getting the vinyl lettering done
  6. Just what I was looking for, I was going to go through the front end & then realized it was the Y drag link. 22 Thanks for taking the time to document & share . Whats with all the ad's covering up the article? Could not get them moved.
  7. Well, I took the plunge & ordered the KYB's, I skipped the OEM match & went up just one notch to Gas a Just.. I wanted the 25% increase in performance/control instead of the Monomax line with 40-45% increase over OEM that I read multiple times daily drivers thought they were 2 stiff. I really don't tow/pull very often mostly job to job with multiple ladders, building materials, etc..and then their is the camper. Should work out great, we shall see.
  8. Next on my Long, long list of things to get done..Clean out those calipers & replace the short section of rubber brake line as they start falling apart from the inside.
  9. Hey Guys sorry it's been so long since I followed up. It's that time of year so business is starting to pick up (no complaints). Wheels and tires are on secure & complete. Here are a couple last details I dealt with making this swap out work. It was barely a 1/32nd that I trimmed off the inner cap on just the rear wheels. I have already taken them in for blancing & we ended with less weights to correct the balance so Good to go there. Lug Nuts:Ebay seller in SC Allens Wheels came up with the right thread & matching closed top. $2.18 a piece oh well. Otherwise it is riding very nice, driving solid. If any one is looking for a set of 20's wheels & tires (on truck in my profile pic) OR a set of stock 16' with center cap. Both set's of wheels have 96% tread depth left. I get an ad up tomorrow sometime. All the best !
  10. Update: (I am still learning the in & out's of messaging, etc on this forum.) Sorry for the delay in getting back to this, work continues to get in the way. Wheels on on. 1.5" spacers were needed for the rear axle as the one piece Wheel/Center Cap was 5/8" to short to fit the axle. I did have to file less than 1/32" off of the inside center diameter on the rear for it to fit Over the rear axle. (this was NOT an area of the wheel that supplied part of the seat) The rear still has 100% full seat to the spacer (as it would have to the drum as well) The front bolted right on. Otherwise the Lug Nuts were an issue: 2018 OEM wheels are 14MM threads, 1999 lugs are 9/16th The Napa lug nuts (see previous post) worked perfectly for fitment, but were open ended & not finished. I have a set that are closed & finished that should work on the way from 2 different suppliers & will follow up with that soon as that is done.
  11. Wow, looks to be a really clean truck. Me, I'm going to advise, go slow. Get to know your truck a bit & sort out what it really needs before doing anything. Pay attention to how it drives..does it drive straight when u let go of the wheel? does stay straight when you apply the brakes? While parked & running, hold the brake so you don't move & put the truck in drive...then to Neutral...then to Reverse...An clunking type noises? Check out the front tires..are they wearing even? cupping..wearing on one side? When you said the transmission was all good did you mean it was on the full mark or do you know to pay attention to the color, the smell? Pay attention to the temp gauge..what gauges does it have? look up what the normal operating range for those gauges..where does your truck run at? Don't feel alone being a newbie, i'm in my first personal diesel myself & of all the issues I've read..A. Auto Trans is not that bad if you upgrade the weak spots. B. Go through your ground contacts, I personally think poor ground wires/connections cause more than half the electrical and/or the wth is going on issues. Good luck!
  12. Thank you for all the input. Sorry for the delay on an update. Here is what I have done/found so far. (I will add that these are my opinion, I am not an expert) The Front rims went right on HOWEVER the lugs HAD to be changed due to the diameter of the seating (obviously the 2018 lugs are 14mm metric as well) I don't believe I will have any rubbing, etc issues at all. My standard lugs were to small & did not seat correctly. See pic's: In the pic. Stock lug & aftermarket stock lug were to small. The gold lug from napa 9/16 that matched the 2018 lug 60 degree seat & overall size fit perfect.(Napa Part # 641-1527 $3.29 each ,Ouch) It also matches the full stud length (the pic may look deceiving on that, but it fits) Then it gets interesting: Rear Axle: Outer diameter of the of the axle is 1/32nd bigger than the rim's molded center cap opening. Only because of the beveled edge. The depth of the molded center cap is appr: 5/8 to short to fit over the rear axle as well. (See pics) My plan: Since we are literally talking such a small difference I plan to remove the part of the bevel (and just a hair more) so it will slide on. (This area that I am removing/trimming is NOT part of where the rim seats to the hub & I will check balance after) I am not a fan of spacers/adapters, etc since the 70's as they were used recklessly, however after reviewing what's available now. I have ordered a 1.5' adapter (not a cheapo) (Moparman I appreciate the pic's you posted about spacers & adapters, but I believe the right fitment will make all the difference.) I was going to find dust covers for the napa lugs, but I believe I found some lugs online of the right size that are closed end & complete for a lot less than $3.29 a piece. (You just HAVE to take the time & sort out the china junk) I will update again asap.
  13. Of the reading I have done on this topic generally the issue becomes A. Lug nuts after 2012 (I think that's the year) when Dodge switched to Metric & B. Center caps So this was new to me. 1.5 hrs away to pick them up & I'm going for it. Will follow up with pic's in a couple days. Thx guys.
  14. Ok first time posting on a forum so if I put this in the wrong category..beat me accordingly. Btw, this site has been Awesome in helping me sort out updates & upgrades for my 99 so Big Thank you to all that contribute. 4th gen 2500 OEM 18" wheels fit a 2nd gen 2500? From what I have read thus far, yes they will. Only 1 issue & that being the axle being out about an inch or so farther on the Gen2. 2" spacers on rear only apparently remedy that. 4th gen tires are 275/70/R18 I have 20" on mine now, but am wanting to downsize just a little. I did find a pic of someone that just recently put the very wheel combo I am wanting to buy on his 1998 with the 2" spacers on the rear with zero problem (so he stated) Anyone have any other info on this be it good or bad?? Thx for the input.
