For those of us who turn wrenches.
Killer223
Interesting reading. Thanks Killer.
BTW, Paint sprayer works like a dream. A small trick after cleaning and blowing out the water with air you unscrew the bottom check ball and housing, turn sprayer upside down and fill the piston with the TSL lube. I think it does fill/ lube the piston and soaks the leather seals and plastic rings.
yes that'll lube the lower packings, but soon as you add paint or any solvent it'll wash it out. and if your spraying doors it'll leave spots on it where the paint took some of the TSL with it and ruined your nice doors.  you can add the lube when storing it, but i use thinner. make sure you flush it very well before doing fine finish work.
