My abs and brake light are one I am thinking a have a front sensor out. I wanted to make sure there wasn't a wire broken and I can't for the life of me even find them and I just missing them or does the wheel have to come off
  • Replies 29
  • Views 4.9k
The front ones come from the unit bearing and should be clipped to the brake line and up in to the engine bay. Just look for the flexible brake line. You dont have to take off the wheel.
That's what I thought and I just can't find it
post-338-0-65864600-1444601708_thumb.jpglooking from behind the right front wheel. My thumb is touching it. If you dont have the wire maybe you only have rear wheel ABS.
Did they all come with front sensor I took a picture not sure how to post it
Not all have 4 wheel abs. If you look at the lower right corner of where you post you will see "More Reply Options". click on that and you can up load them from your camera.
Still cant figure out pictires but I was looks at your post and in one of the pictures the one with the air box off there is a plug and in yours it looks like that is where the abs plugs into and in my truck they're is nothing plugged in to it
Is there anything plugged in on the drivers side?
That's the one nothing is plugged in they're where is it on the driver side
Ok I think I found it right by the abs module and there is nothing in that one also
Yup right next to both towers nothing is plugged into either of them if I could figure the picture thing out it would help. Did all trucks come with them
Mine doesn't look that that though it's just a little black Blox on the side
Ok so I should only have the sensor on the rear pumpkin and one the photo part I don't have the attach file option
You can't attach a photo because I believe that is a paid member option. If you don't have wires coming off the front wheel bearings than it is rear wheel ABS only. I know when the rear sensor went out on my 99 I got both brake lights but the speedometer also quit working.
I do have the lights on but my speedometer is still working just fine
