Explain to me how the 47re shifts
Alright,
I am trying to work through an idea of mine in regards to lockup.  What I am trying to do is figure out how to predict the 1-2 shift and predict the 2-3 shift.  So the question I have is what happens to make the VB decide, Time to shift into 2nd. and what happens in the vb to shift from 2-3.
Is it a pressure difference between the tv and vb pressure?  I don't really understand what happens in the rats nest of a VB.
So is there something I can watch VIA a pressure switch or whatever to show that the trans is going to shift?  Can someone smarter than me explain the magic of how a 47re shifts in low gears?
Reason I am thinking of this is the advent of the Firepunk anteater tranny controller.
How is it that they can control all shifting 1-4 without needing a special VB?   http://www.firepunk.com/anteater/
  • Replies 28
  • Views 35.7k
  • You basically have two different pressures at work in the VB when determining upshift and downshift points. First, there is governor pressure, which is determined by road speed. Early transmissio
  • Ahhhh... I understand your question now. No, governor pressure continues to rise with road speed. Also, FWIW, engine rpm has no bearing on either governor or TV pressure. Only road speed and thro
  • Great work!
    Great work!
    If the little metal tip of the neutral safety switch makes any contact with grounded metal: IE the rooster comb it will start. The plastic bit prevents electrical contact except where it's cut out in
Yes very good.
Great work
Question for you. Just did my 47refresh no issues on assembly transmission full refresh, seals, bushings, steels fibers, all eletronicals.
I did have issues with nuetral safety switch but resolved that now i have ni cruise control. Indicator turns on on cluster but doesnt set.
Speedometer does work everything works but cruise control. Cruise control did work before pulling transmission out of truck.
I realy like cruise control kinda at a loss.  Only issue was nuetral safety switch so my mind keeps going back to it.
On first start up i jumped the plug with a paper clip then figured out i wasn't making contact on switch to switch lever inside pan.
Thanks for your response.
Check the vacuum lines. The battery causes the line to get brittle and crack.
Happened on my truck. Does the backup lights work.
Will check out the vacumn lines and check if back up likes work. I thi k back up bulbs blew 10 years ago or atleast 1 lol.
I have fixed one vacumn line by the battery quute a few years ago. Maybe it rebroke
Got to thinking about neutral safety switch. I rememberd truck used to start in drive.
It now currently will start in reverse, and second gear. Wont start in drive or first.
Tomorrow im going to unplug safety switch jump the prongs and see if cruise control then works with the switch  bypassed
Sounds like the plastic bits that snap into the rooster comb broke. Might have to drop the pan and take a look.
Its been messed up since i installed valve body on the bench. Maybe partly because i had sensor removed when installing valve body.
Being on the bench made it to easy to get it wrong i guess
Plastic bits were still intact on rooster comb
If the little metal tip of the neutral safety switch makes any contact with grounded metal: IE the rooster comb it will start. The plastic bit prevents electrical contact except where it's cut out in park and neutral.  The outer plunger part that has the metal *** in the center gets pressed back in reverse to operate the back up lights.
ounds like the plastic bits that snap into the rooster comb broke. Might have to drop the pan and take a look.b
To prevent breakage the neutral safety switch should be removed whenever the valve body is being removed or installed.
Lol idk do ot right i get it wrong do it wrong i get it right. Ive had tge valve body out a few times without removing neutral switch.
One time on the bench where its easy it goes wonky.
