- Replies 15
- Views 5.9k
BobCat 7 posts
Cowboy 3 posts
AH64ID 2 posts
98whitelightnin 1 post
First, thanks for the help and hand-holding through my oil cooler failure - no more oil in the coolant, and oil analysis shows no coolant in the oil.
Still have a minor coolant leak - I think I have it localized to the thermostat seal rings but not sure. Could be head gasket but no indication of gas in the cooling system - it is an external leak, whatever.
Did y'all know that antifreeze fluoresces in black light all by itself, without any fluorescent dye added? Weird.
Anyway, temperature gauge was acting like the thermostat was stuck open - taking forever to even budge off the peg and never really getting up to temp, so I took changed the thermostat out.
The old one had rubber pieces stuck in it, keeping it from closing. Could not figure out where the rubber sheet-like stuff came from until my wife found a picture on the internet, showing that the stock thermostat has this rubber wrapped around the body of it. Laid out the pieces on the bench and it sure looks like that is where it came from.
Auto parts store Stant 180º thermostat did not have the rubber wrap or look quite the same; put it in anyway. Re-used the two rubber seal ringss that hold the thermostat in place (since I didn't have new ones and it was a Sunday).
Now the engine gets to operating temperature just fine, but if I watch the gauge I can see the thermostat open, temp drop some, then come back up to 180º, then drop some again - like, the old thermostat had the rubber coat on to keep it stable and not have to open and close so much. Temp never goes high, never drops real low, just cycles.
And I think the leak - maybe a cup every week or so - is from the seals I re-used. Damp there, and black light makes it fluoresce just like new antifreeze/water mix I use to top up the overflow tank.
So my question is, do you think this thermostat is ok, or should I get "the right one" (with the rubber blanket on it) and new seals, and change it out?
I value your opinions. Thanks in advance!
Andrew
