Larry - Starting Problems
MY 5.9 has had a issue starting sometimes, will crank but no start! If i tap the injector pump with a hammer while cranking she starts. I installed a fass 150 over 5 years ago she still shows good fuel PSI while running. Also installed new injector pump at 85000 miles 4 years ago.
Edited by CSM
It is just a tap on the top
Anyone know how the shut down works on vp44. old cummins when you cranked the engine it pushed the shut down open when the selinode had power to it. Does the vp44 work the same way.
