Changing a VP44
15 hours ago, Hawkez said:
What will be different with driving it un tapped?
It will still pull more than a commonrail. Night and day difference from stock setting to level 5x5 even without the pump wire tapped. Im geared 3.54 and my 04.5 6 speed was 3.73. The 24v has more get up and go in the 1000-2000 rpm range. Over 2000 rpm not as much difference vs the stock commonrail. but still pulls a bit more.
I'm debating if i'm even going to put the wire tap on. The clutch probably be happier with the wire not tapped. And empty more than enough power.
Edited by moparguy55
Not the same case as my brother's CR...... Trucks were dead even until 75 or so. Then he pulled away.
Edited by TFaoro
