- Replies 6
- Views 2.8k
Dynamic 2 posts
joecool911 1 post
CTcummins24V 1 post
Killer223 1 post
If a torque converter is too tight (or even defective), no amount of valve body work is going to fix that. It sounds like the converter that you put in there is either way too tight for your applicati
With a larger than stock turbo, I'd stay at or near the stock stall speed. It will be an a smoky pig if you don't. But you'll definitely want a more efficient converter than the stock one. The stock c
I had a new torque converter installed about 50,000 miles ago. I'm not real happy with the low stall aspects of it. When you shift into gear it hits pretty hard. My question is...if I installed a towing valve body which increases line pressure, will the shift into gear be even more exaggerated? Is this adjustable at all? Would installing a new valve body increase the life expectancy of my 47re? It's got 215,000 miles on it. I tend to baby the transmission. I don't lug it much. Tend to keep rpms higher when under a heavy load. Third question...with the upgraded valve body can I get more control of shifting? Obviously I can select 1,2 and lock out overdrive. But the control between 3rd and lockup is not available.
