Latest project
Well finding a good used engine wound up being a lot longer ordeal than I thought it was going to be, between guys i was dealing with being wishy washy and or not getting back to me and tons and tons of engines out there out of refer units with way over 10K hours on them which i didn't want to spend near 2K on an engine that was near a $1500-2K  overhaul at which point I could have bought rebuilt engines for less. I finally found a supplier who had a lead on a low hour refer engine "supposedly" in the 3K hour range out of a wrecked truck and his price was really fair in comparison to most I found, getting shipped out tomorrow for a price of $1970 with shipping costs included.
It is a 2005 model engine "Which is 15+ years newer than the tractor" and is a newer style V2203 Direct injection and is 4 HP more then the engine I took out 34 jumping to 38 hp which doesn't sound like much but is actually a lot when dealing with these small tractors.I am replacing a 1.7L engine with a 2.2l engine but externally they are exactly identical and a direct bolt in unit. Hoping to have it by end of next week.
I am going to do a valve adjustment on it and have to swap the oil pan from my old engine over to it as it is designed for the front driveshaft of the tractor to clear and at that point will pull a main and rod cap to inspect the bearings just to make sure i am not wasting time installing the engine that needs work right away.
Probably be a while before getting it done now as I have weekend call at work in two weeks and will need to get other parts ordered for the engine install and then leave on vacation to Florida again right after that. So looking like its going to be a cold December project now in the unheated portion of my shop.
Are you going to just do a visual inspection or Plastigauge them?  Why not just through a set of bearing at it and be done with the bottom end for a while.
Just do a visual. Only reason I  platigauge is when replacing bearings that showed signs of wear to make sure things are kosher with the crank shaft dimensions when installing new bearings,  no need to throw parts at it if it doesn't need it, trying to save some costs on the project otherwise I would have just bought a rebuilt engine with a warranty for another $1500+ but this tractor will not get enough use to justify that extra money.
Edited by Wild and Free
I feel your pain W&F, I dropped my tractor off at the kubota dealer two weeks ago, just do do a pressure test on the hydro-static unit, probably no more than a 1 hour job. and they still haven't got to it.
I would have done it myself but cant come up with the proper fittings to tap into the hydro static unit, Kubota requires their special fittings or buy their hydraulic pressure test kit for about 2k.
If it come to where this is going to cost 2 or 3k to fix. I may be buying another tractor and parting this one out.
If anyone is interested in following along I just started a thread over on the Kubota Forum which will document the project along the way.
http://www.orangetractortalks.com/forums/showthread.php?t=27513
Well here are some teaser pics of the new to me newer version V2203 di engine I got from member cviola for my L2850 engine swap project.
For those in question of this project a quick update is I purchased the L2850 with known bad engine for a song and dance price with numerous attatchements. Found out the crankshaft had broken and upon doing some research found that the V2203 enginges would be a direct swap so the search started. Took a couple months to nail down an engine which took me off guard. Was being picky and wanted a lower hour engine and this one according to cviolas supplier cam out of a wrecked trucks refer and "Supposedly" has roughly 3k hours on it unlike the norm of 10K+ hour refer engines.
Here is a link to my original post with pics of the engine damage of the v1702.
Now the fun begins. i will keep things updated but will be a few weeks before getting too deep into it as work and vacation schedule the next few weeks and then getting a parts list of basics like gasket kits and seals ect ordered for it will take a bit.
http://www.orangetractortalks.com/fo...ad.php?t=25377
First pic was having it loaded up yesterday afternoon in back of my pickup at work where I had it shipped to.
The little B2250 got put to work unloading the engine this morning.
There was a question as to wether or not the exhaust manifold from my old V1702 would fit and work on the V2203 so I did a quick fit test and it will work perfectly.
When I swap the oil pans and drill the block for the dipstick i am going to pull a main and rod cap to inspect the bearings and crank journals before going any farther in case this engine is in need of some deeper work which I hope not.
Then I am going to do a valve adjust right away as well. And then pull the injectors and take them to the injection shop for a quick pop test and clean and adjust if needed and do a compression test at the same time.
Not going through this much work to blindly install a used engine of unknown maintenance and history without doing some investigation of my own.wink.gif
43 minutes ago, dripley said:
Good clean looking motor on the outside. Here's to the inside being the same.:cheers:
I requested he not bead blast, pressure wash and then prime and paint it as that is what he was going to do before he shipped it out, I asked him to ship it as is so i could see first hand what i was dealing with plus i didn't want the issues of having bead blast media stuck in seals and everywhere else to cause issues nor water inside any open intake or exh ports.
hope all goes well, I'm sure their will be some surprises, I do know that those engines can go for 10,000 hrs or so with decent maintenance, before an overhaul, Being it came out of a reefer unit it was probably governed to run at a constant rpm, hopefully you can change that out fairly easy. looking forward to your thread   :thumb1:
We have light plants at work with Kubota engines with 20K+ hours with nothing but basic oil changes, I know for a fact not a single one has ever had a valve adjust even.
Getting fired up and running a set speed its whole life is a lot different than getting varied and heavy loads put on them like in a tractor scenario. Much like comparing a Cummins in an over the road life where a million miles is easy peasy versus a daily driver life where half a million miles would be an extreme stretch.
