- Replies 16
- Views 7.5k
leathermaneod 7 posts
JAG1 5 posts
dripley 2 posts
CTcummins24V 1 post
Popular Days
I have never driven a new 2nd gen, but I bet they weren't perfectly tight from the factory!
My second gen when it only had about 30,000 miles got a DSS steering stabilizer. Not because it was loose steering or any play.... I wanted one because it stops the steering box shaft play from wearin
When mine was new I never could figure why the cops were not pulling me over to see if I was drunk. Constant steering input was needed to keep it going straight unless you were on a major highway. It
Hi all,
I replaced my intermediate steering shaft about 2000 miles ago because it had a lot of play in the upper joint (rag joint I believe) and it did not slide freely. I replaced it with a OEM Doorman one from Rock Auto. Anyway, it has already developed the same amount of play after 2000 miles as the original had after 250k miles. I will not pay $270 for a stupid Borgsen shaft because thats just crazy. So, I was thinking about ways to make this thing better and I came up with drilling out the rivets and replacing them with bolts so that I can
actually tighten up that joint.
What are your thoughts? Good idea or bad? Will it be a safety issue? Better ideas?
