Truck shuts off but starts back up
When my IP went it out off just like that, but never started back up and I had several codes.  If it were ECM or IP related I would imagine that you would have codes and other symptoms, but maybe not.  Do you lose gauges and lights in the dash when the engine shuts off?  I would double check your battery cables, make sure they are tight and clean.
Auto shut down relay. I always thought is was there to shut the truck in an emergency, like  a wreck. I did not think the truck would run without it energized. But it seems the more I tried to find out about it last night the less I knew. Not really sure what it does now.:think:
