Vp44 would this issue guys
Cummins sells the o-rings for the return line. I think Geno's garage does to.
Ok ,one question, the sensor under my IP. CAN WIGGLE  but the Allen head is tight , it makes somethings click in relays maybe this is my whole issue
I can't say my power to vp test was successful but not sure I was getting connection , it's the cam sensor ? Or crank? Not sure the one behind starter is tight,  the one below the IP isn't it wiggles and with key on make sa clicking sound
Edited by ItzReckless
I'm going to guess the sensor is broke. I would pull it out and inspect it. Shouldn't wiggle at all.
Might want to fill out your signature with your truck specs so we can help you better.
Assuming its a early 24V with cam and crank then the crank is the signal for tach and used with the VP44 signal for fueling.
I removed and retightened and it is snug not moving, reinstalled old IP, no start then it tried once but eventually I think my battery's are low so I quit removed IP again , waiting for one from from thoroughbred , my trucks 2001 Vin 7 no sensor behind starter but the one I was actually talking about is right below ecm ?  Will let know how it runs after installing,  ordered fuel pressure Guage,  did not get aftermarket lift pump and don't plan to budgets very thin seeing I'm sinking all this money into a truck I just bought,  I doubt it was crank sensor below the IP it's tight rpms have never jumped always come up when cranking,  but it was a little loose , that I fixed ? Anyhow ttyl when I install new IP
Will edit signature tonight at home always on mobile
