2nd Gen Performance Woes
Mishimoto radiators for second gen dodge:
I just pulled out my FIFTH one in a bit over two years.  Hoses are new, no galvanic issues, even replaced the water pump once while I had it out just for fun.  With me swapping out so often the coolant can't possibly get old.
Their radiators blows a hole in the core after anywhere between 2 and 4 months.  They'll pass an initial pressure test but will fail pretty soon after the install.  It's almost always in the same location but since there's 4 ways to orient the core when attaching the end tanks I can't tell you exactly where it will blow on one you might buy.
There's a mechanic at the shop that does a lot of my work with a Ford and he's on his third Mishi radiator - I wonder if it's the same core with different end tanks?
It's not a big hole so you'll have plenty of time to wait for a warm day and for the warranty swap to arrive.   They will insist on a photo of the leak so hopefully you won't have to pull it out for the photo then put it back until the replacement arrives.  I only had to do that once.
They will ask you to pay them $100 for every warranty swap, and they won't ask for the old one back.
It's a great looking unit and the fit and finish are outstanding if you can get past the "doesn't work" feature.
That's the one that makes me nervous.
My guess, and this is just a guess, is they have a high profit margin and a warranty replace deal with the factory in China.  They certainly aren't going to send it back to China except as beer cans.  But they send my photo of the leaky unit to china as evidence,.
Since China is covering them with a new unit and the $100 covers shipping of the replacement they've already banked the profit and don't much care.
I should add that they were pretty quick with the replacements, typically no more than a week with UPS ground shipping, and they did give me a full refund when I asked for the first time after installing the fifth one.  I did not need to get upity or push them for it.  They were not difficult to deal with at all - just leaky.
I don't have anything clean to catch the antifreeze in except an oily bucket when swapping them so yep, used fresh fluid every time.  I'm pretty fast at swapping them now.  The cheapo replacement I just got from Auotzone didn't go in nearly as easily as a Mishi as the drain valve just barely clears the intercooler outlet pipe.
But, all's well that ends!  I hope!
OK.  New Iquad is installed.
I wish the mods you guys have installed were easier to follow on the mod database page.  It's hard to figure out who has what, also I see only about 9 setup parameters for custom tuning on my android unit.  I have a starting point tune that tech support sent me nut only a few of the fields they sent are available on my unit to change.
Here's what they sent:, but I don't see most of these settings available.
Fuel Load Timing:2
Low PSI Timing Reduct:2
Timing Reduct Scaling: 100
Cruise Timing Adv: 3
Timing vs rpm
1500: 16
2000: 18
2500: 23
3000: 25
Timing Max: 26
Pump Stretch: 1750
TPS Pump max: 100
TPS Pump Min 20
Pump Low Boost Limit: 8
Pump Low Boost Scale %: 0
Boost Scaling: 40
RPM Limit: 3400
Power Reduction: 35
0 PSI %: 87
1 PSI %: 88
2 PSI %: 89
3 PSI %: 90
4 PSI %: 91
5 PSI %: 92
6 PSI %: 93
7 PSI %: 94
8 PSI %: 95
9 PSI %: 96
10 PSI %: 98
11 PSI %: 100
12 PSI %: 102
13 PSI %: 104
14 PSI %: 106
15 PSI %: 108
16 PSI %: 110
18 PSI %: 114
20 PSI %: 118
22 PSI %: 122
24 PSI %: 126
26 PSI %: 130
28 PSI %: 134
30 PSI %: 138
"This is designed to be a daily driver tune on a truck with a VGT and 120HP injectors. Your twin setup and size of injectors should be compatible with this tune. The only thing that I think may cause you any kind of grief is the timing just based off your Hamilton Cam. I'm not sure how it messes with the timing, but if it adds or retards the timing you should take that into account when building your timing section"
Edited by OverToyed
