Boost Issues?
Have a question regarding my boost readings.  I have a DPS 62/65/12 on the truck with 125 hp injectors.  It should be boosting up to 45 psi.  However, I am only seeing maybe 41 psi uphill with my foot on the floor.  I've tried cleaning the MAP sensor out (there was lots of carbon in it), but it didn't get to the levels it should.  I've adjusted the wastegate rod all the way closed in case the drive pressure was opening the flap, but that didn't help either.  Anyone have any similar experiences or advice?  Thanks
