Block Heater Short
Long story short. I plug in block heater GFI outlet breaker trips. I don't see any breaks in the wiring. So is my cord from the block heater bad? Is the block heater bad? or both? It was all working up until this week. I used the same outlet and extension cord with some power tools and they all worked fine.:wts:
Actually the GFCI is a pretty good tester/ indicator that either the power cord or heat element is bad. I happened to my first gen right after the heater was changed. That was finally at about 400k miles the cord insulation cracked and shorted. New cord was $14.95 at O reillys' a few years ago. I installed it with a bit more protection from rubbing by running it thru soft rubber hose in places.
I would try a new cord first, go from there.
Edited by JAG1
