My truck is due for emissions so I removed my edge comp.  When I started the truck the CEL came on and I have a P0237 code.  It will not clear.  I plugged the factory MAP sensor plug into the sensor and no change.  I drove it around and it it runs and drives fine, no smoke.  After driving it a bit the CEL went out but the code is still there (both pending and confirmed).  I pulled up the "Intake Manifold Absolute Pressure" pid on my scan tool and that value seems accurate and responds to driving.  I am going to go out and see if I can determine the voltage...maybe pull the MAP sensor.
Any other ideas?
9 minutes ago, TFaoro said:
Can you clear it now that the CEL is out? If the CEL shut off, it means it's reading fine now.
Nope, even with the CEL out the codes don't clear.  It is not the lamp that is out...it comes on when I turn the key and my OBD scan tool shows that codes and also recognizes that the MIL is not illuminated.
Does anyone know if can read the MAP sensor voltage with the OBDLink?
