My Tranny got HOT!
On 7/3/2017 at 6:52 PM, notlimah said:
When have you needed to use it?
I do not. I had no idea the vb was capable. Lots of racers use it but it is extremely hard on parts. Think of engine torque multiplied by all the gearing in the transmission and then the axle.
Just a passing thought... When was the last time you wash all your coolers? I've been doing A/C repairs in the valley and had several people come to me saying that A/C was poor or weak. Checked everything and pressures is good but the cooler was plugged up with mud and bugs. I wonder if this is your problem as well. You going to want a high-pressure garden hose with a spray gun or remove all the coolers and radiator and clean all them outside the truck. Either way, if the coolers are pack with bugs performance will degrade. Just with my past trip back and forth to Boise at 100-110*F out I tend to power wash the coolers weekly by then after 1,100 miles roughly they are looking a bit buggy and nasty. I know this is not going to fix the slow towing up hill problem but it might just help.
53 minutes ago, Dynamic said:
A gas valve body (46RE) is left stock (as far as lockup goes) because they don't have the benefit of a beefy, multi-disc converter clutch like a diesel does, that is going to hang on at both high power settings and, more significantly, in low throttle, low line pressure situations; ie. descending a hill, locked up, with a heavy load. Mike (@Mopar1973Man), this is why yours won't lock in manual 2nd, or first gear. It's to keep your converter alive and happy...
:smart: Why I like @Dynamic he does the right thing for the owner. I knew we opted out of the whole lock up thing on my 46RE. I kind of knew about 2nd lock up on the 47RE (bit fuzzy) but now I learned about 48RE and 1st and 2nd lock up. That's Neat! Thanks for your knowledge on the topic.
