Sound dampening
32 minutes ago, Mopar1973Man said:
Time to do the valve lash.
I've pulled every bit of sound dampening material off my truck I got sick and tired of finding the mice packing it around under the hood. Even without my sound dampening material, my truck isn't that loud.
Ha I just did the valves! But I’m starting to wonder if I didn’t tighten the nuts sown good enough and they came loose. Reason for thinking this is also becuase
when I let odf the throttle it starts ticking and diminishes as rpms go down.
1 hour ago, Marcus2000monster said:
Do you have a link?
I don't know how to post link from phone.
..on here
do a search. With term  Blanket.
 3rd search result down from top.
The post title is something to do with "Radiator shroud"
Edited by 015point9
..on here
 3rd search result.
Post title is something to do with "Radiator shroud"
Ok thanks!
What is your valve lash set at?
9 minutes ago, Mopar1973Man said:
No. Absolutely not!
Best if overnight cold is best. 140*F or less is OK.
Didn’t think you could lol.
My problem is is I get home at 5 and have to leave at 5 next morning! No time too cool the engine. Settings should be .010 intake and .020 exhaust correct ?
