Posted (edited)
Good afternoon everybody
i have 2 engines
the first is a 1998.5 cummins 24vl w/o trasmission with harness
the secound is a 2000 cummins 24vl with trasnsmission  w/o harness
both are on the ground im plannig to put in my 2003 ford f250
my question is
1: i can start the engine (2000) with the harness of the 1998.5?
2: i need the fuse box to start the engine?
3: the sensors need the connection to start the engine?
Remember......i dont have a fuse box
when i buy the guy say he need so i cant get
i have some colors from the harness...in a video on youtube they say they can start the engine just with 6 cables from the harness to the possitive on the battery
green black
orange black
brown white
red black
red white
red green
and this is the video
Thanks in advance
im from panama by the way so its really hard to find somebody who can deal with my engines
Edited by Eliecerserrano
1. Yes, but see #3
2. No, but you need to ensure everything’s properly fused with the Ford box.
3. No, all the sensors need to be from the year of the ECM, and hooked up to run.
the ford fuse box is not with the engine just imagine i have the 2 engines with harness but i dont have fuse box i try many times to start  just with the 6 cables to the battery
 the fuel pump work and the vp44 click
so that tell me maybe he is right..... the pump send diesel to the injectors but i feel i miss something like when you turn the key to start something like that
i know i dont have any other cable from the inside
:cel:
Is the Ford fuse box installed? You should be able to tap into the OEM wiring harness for things like ECM and fuel pump power.
Are all the pigtails from the harness connected to sensor on the engine? All the sensors are utilized but some are vital.
its not installed...yeah i have some of the wirings so tomorrow maybe i can do another trying
almost all the sensors are connected just the fuel filter have 2 but they are diferents
As for starting these engines you'll need to reprime the fuel system which is most likely got air in the system. So bleed the fuel lines to the VP44 and crack open 1,3,4 injection lines and crank till fuel sprays good or just about starts. Tighten then fire it up. As long as the grid heaters are disconnected you could give it a "very very small spray" of starting fluid to help it along.
Posted (edited)
yes i do that and it split on my head diesel so i know for sure the fuel pump work lol i just use a lil
bit of starting fluid and the engines sounds like is alive but when i stop spray it shut down
when i crank the return line just give me in about 1 min just like 10 drops
2 minutes ago, Mopar1973Man said:
Little trick to bypass all the sensors, ECM and everything. Basically you want to supply power to the VP44 pump alone. It will start and idle only.
https://www.bluechipdiesel.com/troubleshooting.html
thank you for all your help i hope i can try tomorrow i let you know if this work now im going to read
  • Haha 1
Posted (edited)
well i try the best i can and nothing work maybe i should wait for a fuse box and connect the wires to try because the engine still crack but no run
Posted (edited)
i have good news today i try to start the engine and yep its alive!!!
the cables on the harness to start are
red/green
red/white
tan/red
i connect the electric pump directly to the battery
here is the video of the old engine tomorrow i try with the other engine
WhatsApp Video 2018-01-05 at 1.57.06 PM.mp4
now i need to find the cables of the throttle pedal position because the gas pedal or the cable pedal dont work
