98.5 47RE wiring
Looks like there’s 3 plugs on my trans. One I assume is the speed sensor which is near the back. Then there is the big sorta round plug up high pointing down and then there is one on an angle just above the pan. What is that one just above the pan? I’m dealing with my TC not u locking when it should. I unplugged the big round plug and it was still locked and stalled the engine. I unplugged the lower one above the pan and the motor wouldn’t even turn over. There’s 3 wires in that plug, one of them is very twisted up and has a bare spot.
2 minutes ago, Mopar1973Man said:
@Dynamic This is a good one for you to answer.
I've got a funny feeling though something is wrong with the torque converter.
I’ve actually spoken to Dynamic over message as well as a couple others and they have all said most likely the TC is the culprit.
Mostly I’m just trying to confirm it for myself before I pull the transmission out and spend the money on a TC
