Posted (edited)
Anyone have a 5speed that moves while moving in gear shifter moves up and down
Edited by 975speed
That doesn't sound right. Any vibration in the driveline? Does it get worse with speed? Maybe a bent driveshaft? Loose/worn trans mount?
Are you speaking of the vehicle trying to move if try to pull the shifter into a gear without pushing in the clutch in? I do not mean forcing it into gear, just holding pressure on it.
7 hours ago, dripley said:
How many miles on said transmission? Could just be normal wear and tear. My 6 speed with 200k has some movement.
Did you had to rebuild it at one point
No. The one I have now came from the salvage with 52k on it. The truck had about 250k on it at install. That's really about 220k on it.
What happened to the original one, took a bearing out running low on oil?
Got stuck in 4th gear. I had to hulk out of 4th and it would not go back in. Never made a sound or gave any warning. Don't know what happened.
