Tuning for 150hp injectors
Alright, so I just put a set of DAP 7x10 SAC injectors in my 2001. It is a pretty stock truck IMO. Any advice on tuning? I’m trying to cut down on the smoke and avoid having to put around at next to no throttle. Truck is a 6 speed, only mods are raptor lift pump, BHAF, 4” straight exhaust, the injectors, and a quadzilla with iQuad. If I give it more than est. 15-20% throttle, it smokes like crazy. I think I can tune most of that out, and hopefully get some more power out of it. EGTs are below 750 cruising and the stock HX seems to be doing its job. Any help on where to start would be much appreciated.
We have a pretty good list of tunes built up if you are running V2 tunes
https://mopar1973man.com/forum/185-standard-quadzilla-adrenaline-tunes/
Really want it comes down to is you should start with lvl1.  Set your valet mode power % at 80.  do a WOT take off.  Are you happy with power vs smoke?   If you want mroe power increase valet mode % by 5 and repeat until you are happy.
Once you hit dark haze your truck really isn't going to get any faster so that is what you are looking for.
doesn't look like you are running V2 tunes.   I would update your box to run V2 and then choose the V2 vehicle profile.  That will resolve your issues.
Edited by Me78569
When you’re talking about valet mode, are you doing that on a computer or through the app? I don’t see that option on the app. Could have been an update I missed since I’m running the iQuad off an old phone not on the network, but I can get on my WiFi at the house with it.
I updated the box, but on the iQuad app it failed at step 8/9. Right now I’m just running it on level 0 until I get it figured out. I’m going to delete the app and make sure I’m running the current IOS, then download it again and see if that fixes it.
13 hours ago, ICEMAN86 said:
Got it. I’m running 4.10 gears and my tires are 245/75R16s. Hopefully the file looks normal.
1
You good. I was looking for the bigger 35 to 37 inch tires with 3.55 gear which creates a whole new problem. But you just fine the final ratio is good and high making the load on the engine really low.
