How can I eliminate pcm from 01ram 24v
No way to remove the PCM. Its the master computer. Without it the rest of the truck fails.
2 hours ago, mossyoak71 said:
I think you would have to p pump it. Not really sure though as the pcm controls other parts of the truck.
The only thing p-pump does is remove the VP44 you still need the ECM.
ccd network wiring
Ok.
PCM is the master computer
ECM is the secondary computer
PCM uses ECM and ABS.
Cruise control uses ABS signal. (Either pass to the ECM or vacuum motor)
Security feature PCM gets do not start signal and sends to the ECM.
Cluster requires ECM, PCM, and ABS
Cluster gets the coolant temperature oil pressure, and the tach from the ECM.
Cluster gets the fuel level and the voltage from the PCM
Cluster gets the speed from the ABS
ECM requires PCM and ABS module.
ABS control the grid heater canceling.
Radio requires Central Timer (Steering wheel controls).
Central Timer Requires PCM (security feature).
Overhead console requires PCM.
All p-pumping the engine does is remove the VP44. You still need the ECM for the cluster to display gauge functions. Remove the PCM the whole system dies and the truck won't function.
This why the two codes tend to prevent function of the truck typically.
