  • 3 months later...
I just purchased the luberfiner LFF9594 and the donaldson P551315 for my airdog 150 and noticed that they do not have internal orings like the original filters my airdog came with. Is this a problem, or will it affect the performance?
Apache Driver, Thanks for the reply, at least now I have the filters Airdog should have installed in the first place! Chris
AFIK it will be fine. If filters need o-rings they are supplied with them.
Ok am I missing something? the numbers you posted is that the fuel filter numbers only and not the water seperator numbers.
ok..so using the stock fuel filter housings..the 03-07 5.9 common rails.... can use those fuel filters in my truck that is a '01..since they have a better micron filtering?:thumbup2:that would be cool!!!
Yes you can!
I updated the spreadsheet to include some filters with WIF sensors, I am upgrading my system in the next month or so to include an aux fuel heater and 2nd WIF sensor.
  • 3 years later...
