- Replies 7
- Views 11.2k
Mopar1973Man 2 posts
Marcus2000monster 2 posts
IBMobile 1 post
Timburrr 1 post
Popular Days
Check this out.
I just ran water thru mine. Did mine last weekend. Ran enough water thru it to fill 5 or 6 times even some after the water appeared clear. Running a flush thru cant hurt if you want to.
Just done the flush just last week. 350k miles... Still rolling with the OEM water pump and radiator. Heat core replaced once not from scale failure but I found a crack in the water neck that was weep
Could I get a step by step guide to doing a coolant flush? I have never done it since I’ve owned the truck and who knows when it was done last. I will be replacing the thermostat as well. Thanks
