Weird issue with brake pedal feel and PS pump
2 hours ago, Dieselfuture said:
Does that filter come apart and you can change filter elements?
I wouldn't rinse anything unless it's SS mesh.
Yes, that's it in the picture all apart. There is no number on the filter, so there probably is no way to identify it. I went ahead and installed the new one and changed out the fluid to Red Line synthetic.
On ‎9‎/‎20‎/‎2018 at 12:29 PM, NIsaacs said:
Thanks, that's good to know. I will report back after I get some seat time.
Hauled a load of cinder block today, I think I am going to like this new fluid. The truck even seems to drive a little better once I get up to speed. Seems to come off center easier, it used to be really tight. At slow speed it seems about the same, probably the 285 tires.
I was surprised at how thin the fluid was, about like 0 weight. It should work well this winter and flow through the cooler and filter better.
  • 4 weeks later...
