Surging and Turbo Bark under heavy throttle
I've read this turbo information because it's interesting and I'll some day upgrade my turbo to better match 7x009 injectors and programmer
I read through it all on in back of my mind I dont get the its the turbo causing the bark.
I also feel the pump needs addressed soon  even if it is the turbo a upgraded turbo is going want more fuel and be pulling from a pump that's barely hanging in there and may still surge.
My guess is you were set on  buying a turbo before starting the thread as you've got the 500 mark on the brain.
I may need to readjust the bost elbow then. I cant remember but I believe I just closed the port all the way and backed it a turn and it was right at 32. Might have came loose. And with my pump, I'll  try increasing the pressure before I buy a new pump.
  • 5 months later...
Did you ever figure out what the cause was? My father just started noticing it in his truck after I installed a new AEM HD intake. He has an 01 Dodge Ram 2500 ext cab long bed automatic trans with a triple disk TC. Banks tuner, high ram intake, 4” turbo back exhaust and a banks wastegste mod.
