alternator/ transmission help
Your Alternator is throwing out too much AC volts noise is usually the case. Additionally, there is a wiring mode to reduce that AC ripple to less than half when done.
Sorry I can't post a link to the two articles you need ..... one is testing for AC ripple at the alternator...... and the other is W-Ts' grounding mods. Both have helped a lot of truck owners around here.
Welcome to the forum BTW.
