- Replies 17
- Views 3.2k
brantcummins 7 posts
Mopar1973Man 5 posts
AlpineRAM 3 posts
dripley 1 post
Popular Days
The wire strands are the shielding of the VP44 datalink to the ECM. Needs to be there, needs to be connected to pin 3 according to diagram.
That is a normal way to show a shielded pair. With only one side going to ground. I'm not electrical, so my terminology may be a bit off, but the end not connected is "floated" and the o
OK, sorry, should have said connected on pin3 ECM side.. As Mopar1973Man, brantcummins and Haggar correctly observed. Have some experience with buggered shielding on slightly bigger wiring
Alright, guys so it is a long story but I just finished rebuilding the engine on my truck and got it in and am trying to get it started. It is a 01 with a 6spd. I have an airdog 150 installed as well and many other engine parts. I have been cranking and cracking injector lines and fuel will come out but it won't start.
I did, however, hotwire the pump and got it to start and idle just fine as it should so I know my pump is good.. So, that narrows it down to something in the harness or CAN bus wiring. Dont know if maybe I have a bad ECM? I tested the pins on the ecm and all of my power and ground curcuits are good.
Looking for some advice and further diagnosis thanks!
