Can I have two bad thermostats in a row
I found the problem! All the thremostats that I found did look a little different from what I had. While at the counter at Advance auto a lady behind the counter walked by when I was explaining to the other counter person what was going on. She took over from the first person and ask if it was a late or a early 98 and I told her a late. She pulled both and nether looked like what I had originally had. At that point she pulled one for a 99 and there it was just like I had. Went home and installed it and all is good. Flat road , 85 degrees out with the AC on right at 191, 195 up the steepest hill I can find locally  never below 188.
I took a pic. and you can see the difference. I thought that maybe a up date or a different manufacturer so I didn't question it. The flow has got to be twice the stock unit. The one on the right is the old one the one on the left is what 2 different parts houses gave me.
The bypass valve part is a bit bigger and tapered slightly for a good seal.
Any pics of that part of it?
 They really did change the design quite a bit.
Who is they? Cummins or aftermarket?
I've got a 4 year old Cummins one in mine that is like the one on the left.
