**5/6 Speed Owners** Which way are you routing your gauge wires into the engine bay?
I ran the thermo couple wire across the cowl and in thru the hole everything else goes in. I ran the tranny temp wire in thru the hump at the gear shift and mounted both of the "whatcha macallits" that send the signals to the gauges under the plastic trim for the shifter. Both my gauges are on the center of the dash at the windshield. I routed from there around the end of the dash and tucked the wiring down in between the dash and wind shield. Pretty convoluted way for the EGT gauge but not bad on the tranny temp. It would have been easier to put a hole in the dash, just cant make myself do that even now that it is near 6 years old.
Basically with the a pillar I did the same as @dripley where the a pillar ran over the top of the factory trim. Sandwich style then the wires dive past the headlight switch. The sensors are on a custom fitting bracket and tubing to the tap point. This makes for easy testing. I really didn't want to drill holes in my trim back in 2005 when I installed my gauges which was DiPricol back in the day. Now ISSPro EV2 now.
 @Mopar1973Man
Awesome.  Thanks!  I'll try the main harness grommet this time.  Is it a tight fit?  I suppose it's not.  I think that's what swayed me away from doing it the first time.  Was worried I'd be slitting into something and it may not end up working in the long run.
Edited by sooxies
